Thread: Gauge/Speedometer wiring questions
Results 1 to 20 of 22
  1. #1 Re: Gauge/Speedometer wiring questions
    Houston
    I usually wire everything through my ignition wires which are easy to get to right under the dash. But if you dont know what your looking for...a lot of people like to run the wires over to the fuse box in the glove box. I would start with your fuses in your glove box, check them and make sure none are blown. Your gauge problem may be as simple as that. For the overlay, though, the other half of it is still wired in somewhere and you'll need to look for the other half of the connector. Somewhere under your dash. You will need to remove the "knee basher" (remove the two screws and pull it off) to get a better look.
  2. #2 Re: Gauge/Speedometer wiring questions
    Clymer, PA
    okay, i should get a chance maybe this weekend, if i do, let know how it goes, if it goes bad, ill show pix lol
  3. #3 Re: Gauge/Speedometer wiring questions
    Houston
    Good luck! Pics would be really helpful.
  1. Wiring Wideband Gauge
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2010, 02:05 PM
  2. fuel gauge wiring
    By BrokenRhythm in forum General Tech Discussion
    Last Post: 02-27-2010, 04:55 PM
  3. wiring up my VOLTS GAUGE =] 1 Q
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 09-26-2009, 01:50 PM
  4. Wiring questions?
    By GTBabyGirl in forum Visual/Body Modifications
    Last Post: 06-26-2009, 12:43 AM
  5. gauge wiring
    By QwikGT in forum General Tech Discussion
    Last Post: 08-09-2008, 12:46 PM
