Thread: wiring up my VOLTS GAUGE =] 1 Q
Results 1 to 12 of 12
  1. #1 wiring up my VOLTS GAUGE =] 1 Q
    May 2008
    McHenry IL
    ok guys she is in the pod all sodered and wired up shes works great i grounded the bulb and the actual gauge together along with another ground under the carpet on the drivers side floor pan. anyways i tapped into the stereo for when it powers up so does the gauge =] great everything works =] i tested the bulb and everything at the battery all is good and it turns on red i just have 1 question what is the easiest and most accessable to tap into for the gauge illumination again i only want the gauges illuminaition to turn on when i switch the tails n headlights on. "i deleted my drls" anyways what would be the easiest to tap into ??? thanks i took the actually light swtich out but the wiring is way to tight to tap into correctly and successfully so any ideas?? thanks again guys =] GTPSLEEPER I WANNA BUY YOUR BOOST GAUGE =] lol
  2. #2 Re: wiring up my VOLTS GAUGE =] 1 Q
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    there is a grey wire for the radio lights. if you tapped there for power hen u can get the lights from it too. this only works when you turn on lights.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: wiring up my VOLTS GAUGE =] 1 Q
    May 2008
    McHenry IL
    i dont believe so?? i have 2 greys i believe and there for a speaker? i did thing so. but there must be a illunmination to tap into ill check it out tomarrow =] thanks for the heads up any other ideas aguys?
  4. #4 Re: wiring up my VOLTS GAUGE =] 1 Q
    May 2008
    McHenry IL
    i have a 2007 kenwood deck im if not mistaken its a orange wire.... idk we will see thanks guys =]
  5. #5 Re: wiring up my VOLTS GAUGE =] 1 Q
    IRRC orange should be the illumination for your deck. Also the foglight one isn't bad either. Just grab a DMM and test to make sure you've got the correct wire (+~11V at full illumination.)
  6. #6 Re: wiring up my VOLTS GAUGE =] 1 Q
    May 2008
    McHenry IL
    Hahaha funny sotry guys and yes the orange was my illumination =] thanks but your info was to late you lose.... Jk haha thanks for the try though and yeah guys funny story..... Im all good shes great lights up nice and red gauge is perfect then i throw dash and radar detectr back in turn car off and lights off "little did i know i hit the interior light dimmer switch to the left all the way im like wtf i was pissed off cuz the gauge on my pod was real dim then so im like ughhhh started to rip it all apart again.... Then it hit me............. Dimmer haha lesson learned all is well =]
  7. #7 Re: wiring up my VOLTS GAUGE =] 1 Q
    SE Level Member armed's Avatar
    Canada
    I once tapped into the rear plate lights . Another time, I used the wiring going to the center console to illuminate the transmission stick. You just need to test which wire it is. But I think it's safer to tap into the rear lights since there's not risk of a fuse blowing or a computer chip or anything involved.
  8. #8 Re: wiring up my VOLTS GAUGE =] 1 Q
    Any lighting should and must be fused :\
    Any electrical circuits for that matter. If they're not, you're in for a lot of fun when something goes wrong.
  9. #9 Re: wiring up my VOLTS GAUGE =] 1 Q
    SE Level Member reveregtp's Avatar
    Nov 2008
    Revere, MA
    i just threw the wire into my fusebox, and jammed it in with the headlight fuse
  10. #10 Re: wiring up my VOLTS GAUGE =] 1 Q
    May 2008
    McHenry IL
    ghetto but ok lol mine is nice and neat muuuhahaha but if it works run with it =] and yeah duh everything has to be fused armed......
  11. #11 Re: wiring up my VOLTS GAUGE =] 1 Q
    Canada
    I did fuse it thanks for the advice anyway
    I was just stating that in case something goes wrong in any way it's safer to tap into bulbs instead of wires going to chips of computers.
  12. #12 Re: wiring up my VOLTS GAUGE =] 1 Q
    May 2008
    McHenry IL
    good job
  1. Need help wiring amp
    By jjwitty in forum Introductions/Noob Questions
    Last Post: 07-24-2009, 01:59 PM
  2. aftermarket fuel gauge wiring
    By momo29 in forum General Tech Discussion
    Last Post: 03-05-2009, 08:09 PM
  3. 13.25 volts and it wont start, just ticks. HELP PLEASE!!!!!!!!
    By RichCresci in forum General Tech Discussion
    Last Post: 11-15-2008, 08:34 PM
  4. low volts on throttle positioning sensor????
    By DONDON3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2008, 03:28 PM
  5. gauge wiring
    By QwikGT in forum General Tech Discussion
    Last Post: 08-09-2008, 12:46 PM
