can you/ how do you rip out day time running lights, they make me nuts to have my headlights on in broad daylight.
what year is your car? if you have a 97/98 its really easy. pull the fuse. if you have a 99+ you need to bypass some stuff and im not sure what you have to do completely.
you could remove the drl diode, drivers side, dash, there will be a cover when you open the door and look at the dash, remove and its there, its got a big heatsink on it, unplug.
Mine burnt out and i replaced and it did it again, so i said eff it who needs drls anyways
Open the driver door and there is a little cover/door on the side of the dash, inside there is a blue retaining clip that connects to a heat sink....unplug that and the DRL's will go out.
^^^ yea what i said lol
idk about an 02...mines an 03 and it wasn't too hard, needle nose pliers and a small screwdriver was what I used unless you have small hands and can reach in there to unplug it.
