Thread: plastic trim on rear door fell off, please help
Results 1 to 13 of 13
  1. #1 Re: plastic trim on rear door fell off, please help
    SE Level Member Wraith888's Avatar
    Twin Cities
    So are you saying that these clips will hold the panel on without any tape? You just use the tape to add strength to the clips?
  2. #2 Re: plastic trim on rear door fell off, please help
    Used up user
    Jul 2010
    Port St Lucie Florida
    Quote Originally Posted by Wraith888 View Post
    The clips hold the rail onto the door. If you look at the bottom of the panel you'll see that it is made to slide up under the bottom part of the rail, holding the bottom of the panel against the door. The tape holds the top of the panel on.
    03 GTP sedan. Stock. SUCKS
    07 Yamaha FZ1. Also stock, and I'm ok with that.
  1. Door Trim coming off, HELP!
    By PsychoGT in forum Visual/Body Modifications
    Last Post: 02-15-2010, 01:49 PM
  2. Plastic Door Look Pull
    By mike81 in forum General Tech Discussion
    Last Post: 12-17-2009, 09:12 PM
  3. door trim
    By evilpacker in forum Visual/Body Modifications
    Last Post: 07-29-2008, 03:12 PM
