Quote Originally Posted by Wraith888 View Post
So are you saying that these clips will hold the panel on without any tape? You just use the tape to add strength to the clips?
The clips hold the rail onto the door. If you look at the bottom of the panel you'll see that it is made to slide up under the bottom part of the rail, holding the bottom of the panel against the door. The tape holds the top of the panel on.
