Thread: plastic trim on rear door fell off, please help
Results 1 to 13 of 13
  1. #1 Re: plastic trim on rear door fell off, please help
    Used up user
    Jul 2010
    Port St Lucie Florida
    Front & Rear Door Lower Moulding Clip 10261327
    You'll need these to attach the rail and the 3m tape to stick the top of the molding back on.
  2. #2 Re: plastic trim on rear door fell off, please help
    SE Level Member Wraith888's Avatar
    Twin Cities
    How do those clips work? That picture isn't very clear and I thought I just slide the part into the rail on bottom and used the tape on the top.
    (I still have yet to put mine back on, I've been procrastinating).
    Thank you in advance.
  3. #3 Re: plastic trim on rear door fell off, please help
    Used up user
    Jul 2010
    Quote Originally Posted by Wraith888 View Post
    They twist/lock into the metal rail, with the expanding side in towards the door. You slide the expanding clips into the holes on your door and push the post in the back spreading the clips out and holding the whole shebang in. I went to the stealership and was given a quote of $7.95 EACH for the stupid things. How GM went bankrupt charging that much for little plastic clips I'll never know. You need 5 each on the front doors, I have no idea how many you need for the rears.
    03 GTP sedan. Stock. SUCKS
    07 Yamaha FZ1. Also stock, and I'm ok with that.
  4. #4 Re: plastic trim on rear door fell off, please help
    Twin Cities
    So are you saying that these clips will hold the panel on without any tape? You just use the tape to add strength to the clips?
  5. #5 Re: plastic trim on rear door fell off, please help
    Used up user
    Jul 2010
    The clips hold the rail onto the door. If you look at the bottom of the panel you'll see that it is made to slide up under the bottom part of the rail, holding the bottom of the panel against the door. The tape holds the top of the panel on.
  1. Door Trim coming off, HELP!
    By PsychoGT in forum Visual/Body Modifications
    Last Post: 02-15-2010, 01:49 PM
  2. Plastic Door Look Pull
    By mike81 in forum General Tech Discussion
    Last Post: 12-17-2009, 09:12 PM
  3. door trim
    By evilpacker in forum Visual/Body Modifications
    Last Post: 07-29-2008, 03:12 PM
