Thread: HIDS, Alignment and Flickering
Results 1 to 9 of 9
  1. #1 Re: HIDS, Alignment and Flickering
    Iowa
    do you have the reay harness? It draws a constant 12 volts off the battery. HIDs are also very powern specific, batteries are not a steady voltage all the time, hid's don't like this. My suggestion would be to buy the relay if you don't have it. If you have it it could possibly be a bad ballast or ground like I said before.
    Hope this helps a little!
    Eric
  2. #2 Re: HIDS, Alignment and Flickering
    Largo, Florida, United States
    well if the ballst was DEAD the Light wouldnt come on at all
    and if the ground was bad again it wouldnt come on
    I think its a power problem
    for some reason ONE of my lights gets plenty of power
    the OTHER is being a douchebag.
  3. #3 Re: HIDS, Alignment and Flickering
    Where can i pick up the Relay for the HID's?
    and the Odd light pattern is because they aren't aligned properly figured out what i need to do about that
  4. #4 Re: HIDS, Alignment and Flickering
    I'm sending them back to Dash Z Racing.
    tired of being disappointed with non working HIDS
  1. Ahh alignment issues. what is wrong here?
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2010, 12:42 PM
  2. alignment specs.
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2009, 02:40 PM
  3. HID flickering... is this normal?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 06-29-2009, 09:15 AM
  4. What kind of wheel alignment do I need?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-22-2009, 11:23 PM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
