Thread: What kind of wheel alignment do I need?
Results 1 to 13 of 13
04CompG What kind of wheel alignment... 03-13-2009, 09:27 AM
Sabrewings Re: What kind of wheel... 03-13-2009, 11:15 AM
Blown97 Re: What kind of wheel... 03-14-2009, 03:43 AM
Abrasive Re: What kind of wheel... 03-14-2009, 07:56 AM
04CompG Re: What kind of wheel... 03-15-2009, 08:26 AM
Abrasive Re: What kind of wheel... 03-15-2009, 08:55 AM
Iron Indian Re: What kind of wheel... 03-15-2009, 12:40 PM
04CompG Re: What kind of wheel... 03-16-2009, 01:46 PM
Iron Indian Re: What kind of wheel... 03-16-2009, 09:22 PM
04CompG Re: What kind of wheel... 03-22-2009, 08:29 PM
Abrasive Re: What kind of wheel... 03-22-2009, 08:57 PM
Iron Indian Re: What kind of wheel... 03-22-2009, 10:19 PM
04CompG Re: What kind of wheel... 03-22-2009, 11:23 PM
  1. #1 What kind of wheel alignment do I need?
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    I'm going to get a wheel alignment tomorrow. My cars never had it and I can tell how it drives on the highway that it is due (42k miles). Anyway, im having my friends friend do it for me who works at a dealership. He can go in there on the weekends and do side jobs for himself and use all the equipment, which is nice. I called Big O Tires yesterday and asked them how much an alighment is, they said $80!. The guy said it would be a 4-wheel alighment.
    So I call my friend up and ask him how much for his friend to do a side job this saturday for an alighment. He says 50$ and thats it a 2-wheel and that I don't need a 4-wheel and thats its a pain in the ass to to adjust the rear wheels because you have to drill out metal around the strut or something????
    Whats going on here. Thanks.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  2. #2 Re: What kind of wheel alignment do I need?
    Barksdale AFB, LA
    4-wheel. You don't have to drill anything if you know how to do it.
    2009 Subaru Impreza WRX STI
  3. #3 Re: What kind of wheel alignment do I need?
    Feb 2008
    Quote Originally Posted by Sabrewings View Post
    Yup, Sabre is right, when doing an alignment on your W-body you need a 4 wheel alignment.
  4. #4 Re: What kind of wheel alignment do I need?
    Odessa, MO
    Yep, times 3, You need a 4-wheel. What he is talking about is notching the struts. That is only to adjust the camber if it is way out which shouldn't be a huge issue unless you are lowered.
  5. #5 Re: What kind of wheel alignment do I need?
    Feb 2008
    South Bend, IN
    so i need to buy the camber bolt kit and install that in order to do the rear alignment right?
  6. #6 Re: What kind of wheel alignment do I need?
    Odessa, MO
    Quote Originally Posted by 04CompG View Post
    Everything on the rear can be aligned except camber, same with the front. Are you lowered? If not, you probably won't need a camber adjustment or camber bolts. Sorry to say, sounds like your friend is just being lazy, take it somewhere else.
  7. #7 Re: What kind of wheel alignment do I need?
    Moore, Oklahoma
    You definatly need a 4 wheel alignment if you're gonna do it. Otherwise you're half assing it.
    $80 is a rip off... around here you can get a 4 wheel done for $50 anywhere. Or you can be smart like me and go to Firestone and get Lifetime alignment there for $139.99. Alignments for the life of the car. Can't beat that at all, its more than paid for itself with me, i've used it 6 times now over the years...
    Shawn W. Larsen
  8. #8 Re: What kind of wheel alignment do I need?
    Feb 2008
    South Bend, IN
    thanks for the liftetime alighnment info. i called firestone yesterday and its actually $169 now. But thats still worth it expecially if i do one every year. going to consider that.
  9. #9 Re: What kind of wheel alignment do I need?
    Moore, Oklahoma
    Really? Last month here in OKC it was $139.99, tried convincing my dad to purchase it for his car.
    Even if it went up, its still well worth it IMO, i would of still got my moneys worth....
    Shawn W. Larsen
  10. #10 Re: What kind of wheel alignment do I need?
    Feb 2008
    South Bend, IN
    ok got the alignment done. went ahead and bought the lifetime at firestone. they dropped it back down to 140$. the sign in the place still says $169 too. they told me that i do need my camber adjusted. im going to install the bolts myself then bring it back so they can finish the alignment. im going to call them in the morning and ask if i need all 4 bolts of just have to put in 2 of them. do you guys know what bolt to replace with the camber bolts? there 2 bolts that hold the srut in. it looks liek the bottom bolt is what needs to be replaced because thats the one that is attached to the rest of the wheel assembly. im pretty sure he told me it was the bottom one....
  11. #11 Re: What kind of wheel alignment do I need?
    Odessa, MO
    Everything I've read on camber bolts is that if you are only putting one in each strut, you put it in the top hole and get up to + or - 1 degree depending on which way you turn it.
  12. #12 Re: What kind of wheel alignment do I need?
    Moore, Oklahoma
    I bet you'll only need one set of bolts and they will go on the top bolt holes. I have camber bolts on my white car.
    Shawn W. Larsen
  13. #13 Re: What kind of wheel alignment do I need?
    Feb 2008
    South Bend, IN
    yea everything ive looked up online says top hole too. i think ill just do the fronts tomorrow then take it in for an alignment again. hopefully i can return the back bolts because they were freaking $27 each at O'reillys. looks like they are lmost $10 cheaper online.
  1. Proper INTERNAL PRNDL switch alignment pic
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2017, 04:55 AM
  2. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
  3. headlight patter alignment.
    By riceburner in forum Visual/Body Modifications
    Last Post: 09-04-2008, 11:16 AM
  4. Trouble with Alignment after new supsension.
    By John_Shughart in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2008, 06:36 AM
  5. what kind of oil?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2008, 07:37 PM
