Ik wrong section but electronics section is always dead
My friend popped my sunroof for a bit to cool off, then went to shut it and it stopped so i assumed it was shut. However when i got out the roof was still crack about an inch. I push the button and it moves slightly then stops agaain. When i tried to open it, the normal one push openh wouldnt work. I pushed the button once and it moved about and inch then stopped. It did this all the way ack as it was opening. Then when i shut it, the roof slides the correct way but stops at the same spot, about and inch open. It only shuts when i push down on it to help the motor.
Could this be the switch or motor? or does it just need some grease
