Thread: Sunroof still leaks...FOUND PROBLEM FINALLY
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Sunroof still leaks...FOUND PROBLEM FINALLY
    Jersey
    See last page!!!
    Ok this problem is getting old. As a few of you know i had sunroof issues not to long ago. The sunroof is leaking from the interior lights and poors all over my lap when i make a turn or sudden stop. I went ahead and cleaned the drain tubes, and replaced the rubber seal that goes around the sunroof itself. That sunroof seal was $150.00! and my problem still isnt resolved. I was thinking of removing the entire headliner and trying to find where this leak is comming from, but if anyone else has ideas please help me out...
    16' wrx sti- stock
  2. #2 Re: sunroof still leaking
    Feb 2008
    Unfortunately, that is probably your best bet. A while ago there was someone having a problem with a leak by around the wind shield due to some rust through. Just food for thought!!
  3. #3 Re: sunroof still leaking
    Jersey
    Thanx man, i really hope that its not rust .
    16' wrx sti- stock
  4. #4 Re: sunroof still leaking
    Jul 2008
    sumter,south carolina
    just wondering have u had ur windshield replaced lately?
    02 GTP with mods 05 GP for DD
  5. #5 Re: sunroof still leaking
    Jersey
    No, i didnt. I did remove the headliner about 20 mins ago. I had to leave it in the car because i couldnt fit it threw the doors , its just sitting in the back seat, feels like im driving a hoopdie without a headliner . I was going to see if there is another gasket between the sinroof assembly and the roof of the car.
    16' wrx sti- stock
  6. #6 Re: sunroof still leaking
    Jul 2008
    Quote Originally Posted by 99prixgt View Post
    just a shot in the dark,i used to have a 97 GT and had the windhield replaced before i got into autoglass.water was building up in the same spot.turned out to just have a leak though from the install.good luck!
  7. #7 Re: sunroof still leaking
    Jersey
    I didnt know our cars had drain tubes that go out to the rear of the car. I was wondering if they are clogged, it would make sense as to why water comes out when i hit the brakes or make a turn. Im gonna disconnect all four tubes from inside and blow them out with the air compressor tommaorw morning.
    16' wrx sti- stock
  8. #8 Re: sunroof still leaking
    Feb 2008
    I thought you did that already? Can you post some picks of these tubes!!!
  9. #9 Re: sunroof still leaking
    Jersey
    Yeah np. ill get the camera out tommaorw and post some pics
    16' wrx sti- stock
  10. #10 Re: sunroof still leaking
    Feb 2008
    Slower Lower Delaware
    so did you ever figure out what the deal was? I am having the SAME EXACT problem, but don't have time to take down the headliner unless I know that I HAVE to lol. as far as I know my windsheild hasnt been replaced, but I've only owned it for about 6 or 7 months. the water builds up in the dome light housing and then comes out when I hit the gas, brake or turn....its really annoying lol. when its been raining for a while, when I take off, I hear a loud sound of water rushing..so I dont know if it is the drain tubes or not.
  11. #11 Re: sunroof still leaking
    Jersey
    I think I got it this time, im not 100% yet. i pulled the headliner completly, and unplugged all 4 drain tubes, and blew them out with the air compressor really well. The read tubes are very fragile and made from really cheap rubber hoses. It seemed that the ends were cracked, the side that connects to the sunroof assembly. I cut the ends about 1/4" so it would have a nice new seal to the sunroof assembly. Then took zip ties and tightly wrapped the ends of the drain tube inserts. It has been raining in Jersey for the past 3 days and no water fall . I did take alot of pics of the repair job, and how to remove the roof liner,(without breaking anything) Ill upload them soon.
    16' wrx sti- stock
  12. #12 Re: (at least i think) sunroof still leaking
    Oklahoma
    OUTSTANDING! Glad you got it fixed and thank you for taking the pics and doing the write up (if needed). Congrats.
  13. #13 Re: (at least i think) sunroof still leaking
    Jersey
    I was going to ask u if i could post it in the write-up section
    16' wrx sti- stock
  14. #14 Re: (at least i think) sunroof still leaking
    Feb 2008
    sweet maybe thats my problem then
  15. #15 Re: FAILED 2nd attempt at the sunroof leaking
    Jersey
    I wanted to make sure that my solution worked before i made a write-up how to. It turns out that the sunroof is still leaking. Im started to think that its comming from the windsheild seal. <(someone on here thought that was the problem) If you have any other ideas feel free to chime in. I know a couple of you guys have the same problem. Im working on it to figure this out, ill keep you updated if i find out the solution.
    16' wrx sti- stock
  16. #16 Re: FAILED 2nd attempt at the sunroof leaking
    Jul 2008
    lol i had too
  17. #17 Re: FAILED 2nd attempt at the sunroof leaking
    Jersey
    ^ROFL its perfect for the occasion
    16' wrx sti- stock
  18. #18 Re: FAILED 2nd attempt at the sunroof leaking
    Jul 2008
    i thought so too,u been dealin with this prob for awhile...hope u get it fixed.
  19. #19 Re: FAILED 2nd attempt at the sunroof leaking
    SE Level Member snap on's Avatar
    Feb 2008
    Anchorage Alaska!
    some times the rails on the sunroof like to bend just enough to have the sunroof bearly open. Just enough so that you cant tell. I hope that isnt your problem. usually they are a pain in the ass to do. Have fun
  20. #20 Re: FAILED 2nd attempt at the sunroof leaking
    Odessa, MO
    Problem solved.......
    Just kidding, please don't resort to that. LOL! Seriously, I would cover the sunroof in plastic and then tape down all the plastic really well. Then soak the car with a hose for an hour or so. If you still get the water in the light at least you can rule out the sunroof. Which if your drain tubes are clear, I'm convinced it's not the sunroof. Simple fact is, they do not seal which is why it has the tubes in the first place.
  1. HELP! Sunroof
    By GTPluv in forum General Tech Discussion
    Last Post: 10-19-2008, 07:04 PM
  2. sunroof still leaking
    By 99prixgt in forum General Tech Discussion
    Last Post: 08-27-2008, 12:32 AM
  3. Sunroof issues
    By Mikel2k7 in forum General Tech Discussion
    Last Post: 06-28-2008, 11:27 AM
  4. Sunroof problem?
    By 99GPGT in forum General Tech Discussion
    Last Post: 04-25-2008, 10:40 PM
  5. sunroof/moon roof problem
    By TMOTA503 in forum General Tech Discussion
    Last Post: 03-12-2008, 10:00 PM
