Thread: to disable drl the correct way?
Results 1 to 7 of 7
  1. #1 to disable drl the correct way?
    canada
    sorry if this has been asked before..iam getting a set of hid's so i will lose my high beams and i heard i have to disable my drl...can someone please tell me the correct way of doing this? is just to unplug the fuse if so where is it located? thanks this forum is great...
  2. #2 Re: to disable drl the correct way?
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Certain years (up to 2000 IIRC) you can just remove the fuse. There should be a fuse diagram on the inside of your fuse box (inside the glovebox).
    On later years, you have to unplug the DRL diode. Pry up the panel on the driver's side of the dash (can only be seen with the door open). Underneath, there's a black box with a huge metal fins/heat sink. This is the DRL diode. Use a small screwdriver to push the tab, and disconnect the plug that does into it.
    Edit: Try pulling the fuse first. If you have a later model year, you'll hear incessant clicking under your dash. If this is the case, reinstall the fuse and unplug the diode.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  3. #3 Re: to disable drl the correct way?
    canada
    thanks i have a 1999 gtp..so i guess this would be considered a older model? thanks again
  4. #4 Re: to disable drl the correct way?
    SE Level Member 03GTX's Avatar
    Jan 2009
    Edmonton, Canada
    Why do the drls have to be disconnected?
  5. #5 Re: to disable drl the correct way?
    Charles City, IA
    They run at a lower voltage and kill the balasts.
    SMGPFC Two Nipple General
  6. #6 Re: to disable drl the correct way?
    Nov 2008
    Waterloo, Iowa
    The ballasts die if they're running low volt? Why is that?
  7. #7 Re: to disable drl the correct way?
    (It's been a while since I've studied electrical theory, so feel free to correct me if I'm completely off base.)
    Power = current * voltage (P = IV). Therefore, lower voltage = more current (assuming the ballasts are regulated for constant power output).
    Heat produce = current squared * resistance (Q = I^2 * R). Therefore, as current goes up, heat produced goes up, which kills electronics.
  1. cant seem to run the 'correct' afr
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 11:24 AM
  2. Is this how to correct?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2009, 01:52 PM
  3. DRL disable
    By 99prixgt in forum Visual/Body Modifications
    Last Post: 12-16-2008, 09:33 AM
  4. Am I correct?
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 09-08-2008, 08:25 PM
  5. Why is the time on the forum not correct?
    By Andrew_99GTP in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:38 AM
