Thread: to disable drl the correct way?
Results 1 to 7 of 7
Threaded View
  1. #2 Re: to disable drl the correct way?
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Certain years (up to 2000 IIRC) you can just remove the fuse. There should be a fuse diagram on the inside of your fuse box (inside the glovebox).
    On later years, you have to unplug the DRL diode. Pry up the panel on the driver's side of the dash (can only be seen with the door open). Underneath, there's a black box with a huge metal fins/heat sink. This is the DRL diode. Use a small screwdriver to push the tab, and disconnect the plug that does into it.
    Edit: Try pulling the fuse first. If you have a later model year, you'll hear incessant clicking under your dash. If this is the case, reinstall the fuse and unplug the diode.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  1. cant seem to run the 'correct' afr
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 11:24 AM
  2. Is this how to correct?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2009, 01:52 PM
  3. DRL disable
    By 99prixgt in forum Visual/Body Modifications
    Last Post: 12-16-2008, 09:33 AM
  4. Am I correct?
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 09-08-2008, 08:25 PM
  5. Why is the time on the forum not correct?
    By Andrew_99GTP in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:38 AM
