Thread: Cartuning Turbo Kit questions. Need Help.
Results 1 to 17 of 17
  1. #1 Cartuning Turbo Kit questions. Need Help.
    Jul 2014
    Virginia
    I have a cartuning turbo kit and the install has been straight forward until I got to the part of bolting the upper down pip to the back of the turbo. It keeps hitting the master cylinder and wont allow enough clearance to line the pipes up. Does anyone know what ive done wrong?
  2. #2 Re: Cartuning Turbo Kit questions. Need Help.
    iirc when that happens some guys change the brake booster to one off a montie, cause its smaller and moves the master out of the way enough to clear the pipe.
    only going off what ive read here on this tho. turbo guys will chime in im sure.
  3. #3 Re: Cartuning Turbo Kit questions. Need Help.
    Jul 2014
    Virginia
    Thanks man.
  4. #4 Re: Cartuning Turbo Kit questions. Need Help.
    May 2012
    Where winter never ends
    Yep, when this happens you have a few options, some guys beat the pipe with a hammer. I don't like that so I recommend not doing that; however, what you can do is buy a brake booster of a 2000+ Monte Carlo. Bolts right up.
    Unbolt master cyl. (2x 15mm)
    Lookup under dash and pop the clip/spring washer (and pocket them in case)
    Use large bar to turn booster via the bolts counter clockwise if you are looking at it standing in front of the car.
    2000 Regal - Winter Beater
  5. #5 Re: Cartuning Turbo Kit questions. Need Help.
    May 2013
    RI
    Do you have the turbo to crossover bolts loose?
    Greg
    2004 GTP Special Edition
  6. #6 Re: Cartuning Turbo Kit questions. Need Help.
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    A later model Impalla brake booster works aswell, but thats a mod for installing a bigger DP than the CT kit came with.
    The DP that comes stock with the kit should fit without doing that.
  7. #7 Re: Cartuning Turbo Kit questions. Need Help.
    May 2012
    231 is right, usually this only happens w/ a 3in DP.
  8. #8 Re: Cartuning Turbo Kit questions. Need Help.
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    I have a 2.5" down pipe and no problem here. 3" is when it hits
  9. #9 Re: Cartuning Turbo Kit questions. Need Help.
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    What is the absolute smallest one? Is the Impala one much smaller than the Monte one? Need as much possible room as I can get...
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  10. #10 Re: Cartuning Turbo Kit questions. Need Help.
    May 2012
    Think they are the same
  11. #11 Re: Cartuning Turbo Kit questions. Need Help.
    Antioch, IL
    Unbolt the crossover so it moves freely and "jam" the turbo dp in, I wrapped mine because of the zero clearance from the brakes or the valve cover. My next option will be to slot the holes so I can move the booster up and cocked a bit.
    Untitled by smetters20, on Flickr
    2009 Challenger SRT8
    Expert at being gay.
  12. #12 Re: Cartuning Turbo Kit questions. Need Help.
    GTP Level Member
    Jan 2015
    Lincoln, NE
    You need to loosen the xo to manifold bolts and push down on the turbo it will lower everything. Also you can get some 1/4 inch cradle shims that will help gain some clearance
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  13. #13 Re: Cartuning Turbo Kit questions. Need Help.
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Exactly what NebTurboST5 said.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  14. #14 Re: Cartuning Turbo Kit questions. Need Help.
    I have had mine apart a few times over the years. I've always had clearance issues at the rear valve cover corner, the A/C pipes on the firewall, and the top of the transmission housing where the connector is. Best bet is to hook everything up loosely, get some wood shims like you'd use around the house. Jam them in between your two rough spots, the pressure will keep things where you want it as you bolt it down. Good luck!
  15. #15 Re: Cartuning Turbo Kit questions. Need Help.
    Feb 2008
    NY
    Besides being a pain to change plugs with a CT kit the biggest issue I have is the lower corner valve cover bolt gets blocked like Damnir. Have to loosen upper DP to get too.
    I wouldn't use wood shims due to heat.
  16. #16 Re: Cartuning Turbo Kit questions. Need Help.
    GTP Level Member
    Jan 2015
    Lincoln, NE
    you could wedge everything around with wood shims but after you torque everything down definitely pull the shims out so they dont catch on fire...
  17. #17 Re: Cartuning Turbo Kit questions. Need Help.
    LOL, yes pull the shims out.. I thought that was a given... My mistake for not saying to do so!
  1. Cartuning Turbo kit, ZZP HID kit, 8 Rib setup, Springs and MORE
    By glanzergtx in forum For Sale - Parts
    Last Post: 03-24-2017, 05:33 PM
  2. Cartuning Turbo on 05 GP GXP
    By gxpmike05 in forum 5.3L V8 (LS4)
    Last Post: 06-23-2013, 11:31 AM
