Thread: grand national turbo exhaust manifolds
Results 1 to 20 of 29
  1. #1 grand national turbo exhaust manifolds
    Kemmerer, Wyoming
    anyone know if grand national turbo exhaust manifolds will bolt up to series 2/3 heads?
  2. #2 Re: grand national turbo exhaust manifolds
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I highly doubt it, differnt heads/block.
    And why when plogs are cheap and flow better anyhow.
  3. #3 Re: grand national turbo exhaust manifolds
    Kemmerer, Wyoming
    power logs might be the best way to go, but there would be a lot of other exhaust that would have to me fabbed if I go that route. if the grand national manifolds bolt up there are kits available to do the whole installation. if they do fit, there would probably be some custom work required, but I would imagine it would be a lot less.
  4. #4 Re: grand national turbo exhaust manifolds
    a grand national is rwd and has a huge engine bay, so its not gonna fit even if it could fit is my guess. there would still be a load of fab work.
  5. #5 Re: grand national turbo exhaust manifolds
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    Different exhaust port layout. Will not bolt up.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  6. #6 Re: grand national turbo exhaust manifolds
    May 2012
    Where winter never ends
    Couldn't you do front and rear PLogs and a z7 cross over? I think that all bolts together and then you have the T4 turbo flange
    2000 Regal - Winter Beater
  7. #7 Re: grand national turbo exhaust manifolds
    Kemmerer, Wyoming
    Quote Originally Posted by ADecker View Post
    maybe, I will have to look into that
  8. #8 Re: grand national turbo exhaust manifolds
    GTP Level Member
    Jan 2015
    Lincoln, NE
    what are you trying to do?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  9. #9 Re: grand national turbo exhaust manifolds
    Kemmerer, Wyoming
    I'm not trying to do anything yet, just thinking about doing an f body 3800 turbo build, pull out all the stops and do a max build
  10. #10 Re: grand national turbo exhaust manifolds
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    If going all out, why not go with a custom, stainless hotside?
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  11. #11 Re: grand national turbo exhaust manifolds
    Nov 2011
    NY
    Quote Originally Posted by WhiteLightningGTP View Post
    ^^^this^^^
    http://www.mandrel-bends.com/catalog/
  12. #12 Re: grand national turbo exhaust manifolds
    Mar 2012
    NC
    Because modifying the aftermarket 3.8 turbo stuff is cheaper and less time consuming than building all one off stuff.
  13. #13 Re: grand national turbo exhaust manifolds
    Kemmerer, Wyoming
    Quote Originally Posted by Sven The Baldman View Post
    its easier to make something work than build from scratch. a kit will have most of the items required, if not everything. and so far I haven't found a complete kit for a 3800 rwd, except the cartuning kit which required an ac delete
  14. #14 Re: grand national turbo exhaust manifolds
    Mar 2012
    NC
    Quote Originally Posted by SgtMarshal View Post
    Believe me...I know. I make one off crap all the time...it may not be as fancy as some others, but I still do it with minimal tooling to get it done.
  15. #15 Re: grand national turbo exhaust manifolds
    Kemmerer, Wyoming
    <------- complete noob here when it comes to building new or even modifying a turbo kit. haven't messed with turbo's at all. I picked up a couple books that I am going to read to get edumacated.
  16. #16 Re: grand national turbo exhaust manifolds
    May 2008
    Schuyler, NE
    My suggestion is to find a pair of 3.8 mustang manifolds and use those.
  17. #17 Re: grand national turbo exhaust manifolds
    GTP Level Member
    Jan 2015
    Lincoln, NE
    do you flip them like on a LS turbo setup?
  18. #18 Re: grand national turbo exhaust manifolds
    May 2008
    Schuyler, NE
    Yeah if you want the turbo in the front.
  19. #19 Re: grand national turbo exhaust manifolds
    GTP Level Member
    Jan 2015
    Lincoln, NE
    they clear all the accessories?
  20. #20 Re: grand national turbo exhaust manifolds
    Banned
    CT
    You should get them l33t ported for like 1700 bucks.
    I hear a l33t port job is worth like 70whp over a vendor stage 2 port.
  1. Turbo Regal vs mid 500whp Grand National
    By SnowFlake in forum Track Sessions and Kills
    Last Post: 06-06-2014, 09:12 AM
  2. Twin Turbo LSX Grand National
    By Below Average Joe in forum Off Topic Discussion
    Last Post: 08-08-2012, 10:06 PM
