Thread: what motor oil do you guys use?
Results 1 to 15 of 15
  1. #1 what motor oil do you guys use?
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Just curious. I mainly use RP HPS 10w30. When I need to do a quick change I use Mobil 1.
    Heard Rotella T6 is good for turbo applications.
    Saw couple of vids that Mobil 1 and RP work very well for turbo applications.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  2. #2 Re: what motor oil do you guys use?
    SWPA
    Whatever is on sale LOL
    For turbo cars yeah Rotella is used a lot. I think I actually ran it in my TSI back when I had it.
  3. #3 Re: what motor oil do you guys use?
    May 2012
    Where winter never ends
    I use Castrol 5w-30 full synth, I'm turbo... never really thought of it
    2000 Regal - Winter Beater
  4. #4 Re: what motor oil do you guys use?
    Antioch, IL
    cheapest you can buy 5 30
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: what motor oil do you guys use?
    Seeing how this is the turbo section and I don't own a grand prix anymore but I will chime in anyway.
    On the truck board that I am on, many guys over there are turbo'd and I'd say most run heavier grade oil than 5W30. Rotella T6 is a great option because it's a 5W40 synthetic. Some have said mobil 1 gets "used" up faster and can't take the high heat aswell. Though alot of these guys are pushing 500-700 whp on a daily driver truck.
  6. #6 Re: what motor oil do you guys use?
    hangover park IL
    t6 5w40 diesel oil
    its OTR truck oil so the additive package should be more robust, not to mention actually having zinc that gas engine oils lack due to it killing cat's
    its also cheap
    i use the non syth rotella in my daily's... **** the cat, save the engine
    ~James~ Psychotic Gearhead
  7. #7 Re: what motor oil do you guys use?
    Ive heard of people using rotella in the 3V 5.4s to keep them quiet I basically I should use this in my navi and everything else?
    ROTELLA EVERYTHING!?
  8. #8 Re: what motor oil do you guys use?
    Nov 2012
    Erlanger, KY
    Mobile 1 synth here.. But usually after every two to three race events it gets changed out, so its no in there long anyways.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  9. #9 Re: what motor oil do you guys use?
    GT Level Member mikejohnlewis's Avatar
    Jul 2014
    Manchester, Iowa
    ^^same, except I haven't gotten mine out much yet.
    1997 Grand Prix GT 3.8(SOLD)
    2002 40th Anniversary Coupe GT (SOLD)
    2000 Daytona Coupe GTP (Summer Car)
    2011 Ram 1500 (daily)
  10. #10 Re: what motor oil do you guys use?
    I break stuff selliott's Avatar
    Kansas City
    Amsoil dominator
  11. #11 Re: what motor oil do you guys use?
    Feb 2015
    I prefer Pennzoil but usually what's on sale
  12. #12 Re: what motor oil do you guys use?
    GT Level Member jake91's Avatar
    Jun 2012
    mesa az
    Amsoil signature
    2003 Pontiac Grand Prix GTP, thrasher intake, intense poly upper mounts, 06+ Impala dual piston calipers, 88k miles
  13. #13 Re: what motor oil do you guys use?
    Banned
    Jan 2013
    Colorado
    virgin olive oil
  14. #14 Re: what motor oil do you guys use?
    Antioch, IL
    I prefer COLD PRESSED EXTRA virgin, your running the cheap crap
  15. #15 Re: what motor oil do you guys use?
    Jul 2012
    Chicago
    Been running Rotella T6 for the last 20 miles now. Blackstone says I can run it for 10k if I wanted to. I'm just an NA slowkar though. I like it cause it's cheap, and the slighter thickness makes my motor not burn any oil.
    -Carl
  1. Guys Need Help! 8.5 degrees of knock on a Stock Motor?
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2013, 04:17 PM
  2. Blower fan wont turn off with motor running , stops with motor off
    By bosull in forum Introductions/Noob Questions
    Last Post: 04-20-2012, 07:32 PM
  3. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  4. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
