Thread: Car back together now I have a weird MisFire problem...
Results 1 to 5 of 5
  1. #1 Car back together now I have a weird MisFire problem...
    Aug 2011
    Millbury, OH
    Well I finally got my car back together and running. Took the car out for a test drive and noticed I have a weird miss. When the car is in lower rpm's you can feel it more, especially in overdrive. It seems to buck in overdrive when going up hill.
    So I replaced the plugs, wires, coil packs, cleaned the MAF, checked for vacuum leaks, replaced the fuel filter and t still has a miss. I don't notice it when I'm on the gas so to speak.
    When I pulled the plugs #4 spark plug was black all the rest looked normal. Seems like the miss doesn't change idling when I pull the number 4 spark plug wire.
    So.... Thoughts? I was going to swap around injectors and see if I notice a difference.
    2000 GTP coupe, Stattama Turbo Setup, A/A intercooled, custom cam, Tischler heads, 3250 stall, Zzp trans, 1" GMR chain, 65# injectors MDP hood, MSP exhaust, and much more.
  2. #2 Re: Car back together now I have a weird MisFire problem...
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Sure the spark is making it all the way down the wire? Cracked insulation on plug? If the plug is black the injector is working.
  3. #3 Re: Car back together now I have a weird MisFire problem...
    Aug 2011
    Millbury, OH
    I replaced the plugs and the wires. Still the same...
  4. #4 Re: Car back together now I have a weird MisFire problem...
    Jan 2009
    Tallahassee, FL
    For the future please use black font, other colors are hard to read and make me less willing to read a post
    Anyways, since you've replaced the whole ignition system already I'd start looking in other areas. Check the ICM and wiring, make sure the injectors and wiring is good as well. What work did you do to the car?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: Car back together now I have a weird MisFire problem...
    Aug 2011
    Millbury, OH
    I installed a new stattama crossover, downpipe and PLOGS. The old setup was in made out of mild steel and the rear manifold was in bad shape. It was one of the first stattama kits and was custom so I couldn't just replace the manifold.
    I ended up replacing the injectors with new ones and the misfire went away.
  1. Weird misfire
    By dmahlikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2012, 12:47 PM
  2. Weird Tapping from back of engine
    By wpbboy81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 06:20 PM
  3. Really weird problem!
    By pyccke87 in forum General Tech Discussion
    Last Post: 10-03-2009, 10:22 PM
  4. weird problem???
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2009, 12:44 PM
