Thread: Weird Tapping from back of engine
Results 1 to 19 of 19
  1. #1 Weird Tapping from back of engine
    SE Level Member wpbboy81's Avatar
    Sep 2011
    west palm beach, fl
    I just need some opinions as far as what to look for. I noticed a tapping sound in the back of my engine after my header install, but forgot about it. Yesterday i was noticed it again and figured i'd ask if anyone knows what it is. Standing on the driver's side, it sounds like its coming from the rear valve cover or EGR pipe on the exhaust, but i dont knw. My headers arent touching anything, and my trans stick is ziptied to the brake booster hose ( i think)....i cant remember right now. Its weird because when i rev the engine even a lil bit it goes away. It's only when the engine is idling that the tapping is present.
    98 GTP, VS cam, SD headers, 3" full exhaust (cat/resonator/ubend deleted), genV blower, 3.4 MPS, ported LIM, open cone air filter, custom tune, alternator power cable, fuel pump rewire, AL 104s, 180 stat, flipped dog bones, 04 GTP front rotors w/ F-body calipers, and the oh so comfortable monte carlo seats
  2. #2 Re: Weird Tapping from back of engine
    could be a lifter tick or even your fuel injectors just being noisy.
  3. #3 Re: Weird Tapping from back of engine
    Sep 2011
    west palm beach, fl
    is lifter tick bad? im not too worried if its just the fuel injectors being noisy
  4. #4 Re: Weird Tapping from back of engine
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    knocking coming from the back of your engine?, perhaps there is a little person in there wanting to get out
  5. #5 Re: Weird Tapping from back of engine
    If your very unlucky it could be the flex plate.
  6. #6 Re: Weird Tapping from back of engine
    Sep 2011
    west palm beach, fl
    like, it could be bent?
  7. #7 Re: Weird Tapping from back of engine
    cracked or bent
  8. #8 Re: Weird Tapping from back of engine
    Sep 2011
    west palm beach, fl
    guess i'll b checking that...hope dats not it
  9. #9 Re: Weird Tapping from back of engine
    Kansas
    If it is a tapping sound, could be an exhaust leak coming from the manifold. This would be my first guess since you said you just did a header install. Maybe you didn't you didn't torque them enough or just got a bad gasket.
  10. #10 Re: Weird Tapping from back of engine
    Omaha, NE
    Rear manifold / downpipe leak?
    Edit: Negger is a Ninjer!
  11. #11 Re: Weird Tapping from back of engine
    Or better yet, the flex pipe.
    SD's are known for it.
  12. #12 Re: Weird Tapping from back of engine
    Sep 2011
    west palm beach, fl
    I do remember reading that SD's are known to have leaks. how do u check for exhaust leaks?
  13. #13 Re: Weird Tapping from back of engine
    feel around and see if you can feel any spots where exhaust is blowing out if not then put some seafoam in it and look for where the smoke comes out.
  14. #14 Re: Weird Tapping from back of engine
    Sep 2011
    west palm beach, fl
    ok, i'll do that...thanks. hopefully its an easy fix
  15. #15 Re: Weird Tapping from back of engine
    SE Level Member pontiacgtp24's Avatar
    Jan 2012
    Michigan
    Sounds like a lifter issue.Get yourself a quart of lucas engine oil stabailzer poor it in at next oil change and see if the noise has decreased.could also be manifold leak but they sound completley different.does the noise seem louder when it cold but goes away when its warm?those hydro-lifters in gms are a common problem .my grand am 3.4 did the same thing
  16. #16 Re: Weird Tapping from back of engine
    Sep 2011
    west palm beach, fl
    Quote Originally Posted by pontiacgtp24 View Post
    I'll have to check, i never took a listen once the engine warmed up. its not noticeable unless the hood is open and i'm standing on the driver side. but i'll try listening at cold and warm. im really hoping its just an exhaust leak.
  17. #17 Re: Weird Tapping from back of engine
    Sep 2011
    west palm beach, fl
    the seafoam idea seems like a good one, but it sucks cuz i seafoam my engine every 2 months, and i just did it about a week ago, so i doubt they'll be much smoke if any. everytime i do it, the smoke is lighter and lighter...kinda sucks, cuz i like the smoke show lol
  18. #18 Re: Weird Tapping from back of engine
    Jan 2012
    Michigan
    your talking about a top engine cleaner if im not mistaken.that wont help this problem.its lucas motor oil addative.it a quart of oil thick as molasses. the idea is thicker oil means less oil pressure leak down from a hydo-lifter seal.Its hit and miss but its only 10$ for the stuff.worth a shot and it cant hurt the engine.if you posted a vedio of the car making the noise that would help narrow it down
  19. #19 Re: Weird Tapping from back of engine
    Sep 2011
    west palm beach, fl
    oh nah, i meant the seafoam for the idea of seeing if i have a leaky exhaust by lookin for smoke seeping. but im gonna try the lucas to see if it helps
  1. Engine tapping noise under load and cold only
    By mojonba in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2011, 09:07 PM
  2. tapping in engine
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2010, 11:13 PM
  3. weird noise from engine
    By carl06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2009, 06:50 AM
  4. Engine weird sounds/chugging
    By ajm786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2009, 09:18 AM
  5. My engine tapping noise with Video
    By 04CompG in forum General Tech Discussion
    Last Post: 12-12-2008, 02:57 PM
