Thread: Throttle body waste gate issues!! Please help!!1
Results 1 to 7 of 7
  1. #1 Throttle body waste gate issues!! Please help!!1
    Jan 2012
    RAVENSDALE
    Hey Guys, Im am running into a slight issue. I have done an entire turbo install using a gutted S/C for the intake manifold. Well Everything is bolted in and looking good, but the throttle linkage is hitting the lower vacume line fitting on the Tial waste gate at about 1/3 of the rotation. Does anyone know if a throttle body spacer is needed to push the throttle body out to clear the wastegate? That seems to be my only option at this point, unless there a way to spin the head of the waste gate??. I dont want to go buy a spacer and that not be the issue and it throws all my I/C piping off. Any help would be greatly appreciated.
  2. #2 Re: Throttle body waste gate issues!! Please help!!1
    Texas
    What kit is this? Pictures when you have a moment please.
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: Throttle body waste gate issues!! Please help!!1
    Jan 1970
    Maquoketa, Iowa
    Yeah it helps to know what kit you are using.
    Also you typically want to leave everything loose to be able to adjust for things like this, then tighten back up once everything is clearing.
  4. #4 Re: Throttle body waste gate issues!! Please help!!1
    May 2008
    Schuyler, NE
    What wastegate are you running?
  5. #5 Re: Throttle body waste gate issues!! Please help!!1
    Texas
    Stated in the 1st post....
    Quote Originally Posted by 1997GTPFUN View Post
    85 Corvette
    01 TA
    03 Z06
  6. #6 Re: Throttle body waste gate issues!! Please help!!1
    Feb 2009
    flintnasty MI
    There are probably 8 differnt styles of tial gates.
  7. #7 Re: Throttle body waste gate issues!! Please help!!1
    SE Level Member BlackGS's Avatar
    Central Jersey
    When I first installed my wastegate, the lower vac connection was hitting the s/c housing, so I notched the housing (see pic). Then someone told me that the waste gate can be turned anyway you want. Doh.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  1. throttle issues
    By KSGTP in forum Introductions/Noob Questions
    Last Post: 09-28-2012, 01:09 PM
  2. ls1 throttle body
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2011, 05:33 PM
  3. Throttle body in an 08
    By zenman400 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 09:01 AM
