Thread: throttle issues
Results 1 to 6 of 6
KSGTP throttle issues 09-24-2012, 04:20 PM
blackspike2710 Re: throttle issues 09-24-2012, 04:43 PM
matt5112 Amd other vendors sell that... 09-26-2012, 08:43 AM
KSGTP Re: throttle issues 09-27-2012, 10:01 PM
matt5112 Re: throttle issues 09-28-2012, 07:31 AM
1ATony Re: throttle issues 09-28-2012, 01:09 PM
  1. #1 throttle issues
    Aug 2012
    Kansas
    I have an 01 gtp that has the newer generation (04+?) intake and supercharger. I am having issues with the throttle sticking. I had previous issues with this and when i took it to the shop thry took the throttle body apart and cleaned it, but said that it looked bad and that i should probably get a new one. They wanted $800 for the part and $200 for labor. I looked online and found a northstar throttle body conversion kit for $579 at 3800 performance. It states that it is for 97-08 grand prix. My question is with the different generation intake, will this still bolt up? My assumption is that it would since it says it's for 97-08 and even though it's a different intake, it stall falls within that range, but we know where assumtions get us. Am i getting in over my head? How hard would this install be? Should i just try cleaning the throttle body i have again? Any input is appreciated.
  2. #2 Re: throttle issues
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    So you have an 01 GTP with a Gen V top swap. You likely have a throttle body adapter running the factory throttle body. If you are not running extensive mods the factory replacement will do you just fine. $800 for the part is BS and it only takes five minutes to swap them, you can do it your self with a trip to the part store. Post pics and additional info for further help.
    GPONA #1 Cyber Bully
    Amd other vendors sell that tb kit for half that.
  4. #4 Re: throttle issues
    Aug 2012
    Kansas
    The Northstar conversion? Where at? And in your opinion, is it worth it to upgrade?
  5. #5 Re: throttle issues
    How do you know your TB is "bad"? How is it defective?
    From this section: http://www.grandprixforums.net/new-m...ads-36503.html
    Very first link: http://www.grandprixforums.net/safel...car-17482.html
    If you're stock, the N* TB is too big and not worth going from progressive to linear throttle style.
  6. #6 Re: throttle issues
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  1. Throttle Body? MAF? What is what?
    By davidinark in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-16-2011, 10:15 AM
  2. L36 Throttle on L67
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2010, 08:08 AM
  3. Throttle body in an 08
    By zenman400 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 09:01 AM
