Special as in can't imitate with custom grind or special as in a really ****in good cam? Lol because that turbo kit with a custom grind like the st2 is kinda the setup I'm starting to lean towards.
Also is the l26 top that much better? Because zzp jus told me to run the l36 with the hv3 insert. So I'm jus tryin to decide what will be better for my setup
Also lets be honest will drag radials be enough to hook or will slicks be needed? I have a friend running Toyo proxis drag radials and he says they hook great but I know a turbo build is way more power n harder launches than his s/c build
