Thread: turbo build
Results 1 to 6 of 6
  1. #1 turbo build
    GT Level Member Twist's Avatar
    Jul 2011
    Kitchener
    ZZP Z7 Turbo Kit
    Liquid/Air Intercooler
    HV3 Insert
    42# Injectors.
    10psi
    overkilled
    3" to Magnaflow y-pipe
    2.5 split to Magnaflow polished stainless mufflers
    *current mods
    looking to upgrade a bit over the winter
    want reliable horsepower
    im doing n* tb and ls6 springs and uping boost abit
    any other suggestions?
    2009 Rabbit
  2. #2 Re: turbo build
    1.9's might help.
  3. #3 Re: turbo build
    Jan 1970
    Maquoketa, Iowa
    Drop the N*
    E85 or maybe methanol if not wanting to go with 65# inj.
    May even want to consider the Z3 kit. Save a few bucks and don't really see much of a drop in hp vs. the z7. Think of the Z3 as a hybrid kit designed to make the best/reliable power per dollar.
  4. #4 Re: turbo build
    Jul 2011
    Kitchener
    Quote Originally Posted by FoSHO99 View Post
    Drop the N*
    should have specified that the top mods are what im running already atm , *fixed*
    havent looked into E85 much ,sum to consider
    2009 Rabbit
  5. #5 Re: turbo build
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Twist View Post
    If it's available to you, you don't mind the less mpg and free horsepower. You'll find it's very hard to get knock on E85.
    What type of water/air intercooler do you have? Ever look at air temp drops on it?
  6. #6 Re: turbo build
    Z3 is open dump?
    Not so emissions friendly.
    I was under the impression Z7 was internal?
    Two E85 stations in Canada: guelph and ottawa.
  1. planning a turbo build
    By nascartech in forum Turbo
    Last Post: 02-10-2011, 06:59 PM
  2. Build your own turbo headers
    By Deimos in forum General Tech Discussion
    Last Post: 01-23-2011, 10:22 AM
  3. Few turbo questions for the build!
    By 98GT3800 in forum Turbo
    Last Post: 08-13-2010, 08:42 PM
  4. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
  5. Turbo build advice: GTP and GS mating..
    By LowlyfeGTP in forum Turbo
    Last Post: 05-27-2008, 11:29 AM
