my biggest goal is fast ass 1/8 mile times and take it to the 1/4 once in a while (1/8 mile is 40 miles and the closest 1/4 is about 2 hours lol)
Yea i just got all excited when i seen them lol. So is wanting to reach my 450-500whp goal totally possible with the st2 cam and that turbo, or would i wanna go with a little bit bigger turbo or diff cam? also thank you for giving me an rpm range of spool ive been asking a bunch of people and never get any response aside from quick or slow lol
Special as in can't imitate with custom grind or special as in a really ****in good cam? Lol because that turbo kit with a custom grind like the st2 is kinda the setup I'm starting to lean towards.
Also is the l26 top that much better? Because zzp jus told me to run the l36 with the hv3 insert. So I'm jus tryin to decide what will be better for my setup
Also lets be honest will drag radials be enough to hook or will slicks be needed? I have a friend running Toyo proxis drag radials and he says they hook great but I know a turbo build is way more power n harder launches than his s/c build
Special as in it made damn good numbers.
Just run the l36, I don't know why everyone says l26 or gtfo.... Personally, the l26 is kind of a fail in my eyes in some aspects.
For the most part drag radials will be good enough.
Stattama.com has all the cam specs on the site.
I like that the l26 is aluminum and I'm running it with the insert. Nothing wrong with the l36 upper really but I thought I heard they can't handle really high boost.
j/w but what kinda boost #s COULD I be talkin off of all this? will i be raising my shift points/rev limit? and should i be runing the 85mm maf or is the stock maf good enough?
The afc scales how the PCM reads the maf single so that you have more room on the maf. Hpt doesn't have that ability. You should a stock ported tb with the 99+ maf as said above, most have had trouble tuning with the bigger tbs.
OK I wasn't sure I seen the mini one and the gauge one but wasn't sure if others made any diff ones or not..
Thanks ALOT for all your help guys seriously its greatly appreciated. Ima start piecing everything together finally lol.
Also does anyone know how to get ahold of triple edge performance? I've sent several emails to there email on there site but haven't herd back from anyone and Im needing a trans soon lol
Don't give up on Dave and Triple Edge, yeah it takes a while for him to answer emails some times but he is a great guy and really knows these transmissions. Quickest way to contact would be to call. When he is busy, he doesn't have time to sort through all his emails. He is modding my valvebody right now and I ordered some other parts I needed to finish my transmission build. Awesome company! Worth the wait to get ahold of him.
On another note, I am pretty sure I saw a complete l26 uim/lim combo for sale on here in the classifieds for pretty cheap. IF not, it was one of the other 2 grand prix sites I visit. Not sure if it was already plugged or not, but like someone else said, you can tap and plug the injector holes probably easier than welding. The manifold I bought was done that way with anodized pipe plugs in the holes. You decide to buy a new kit or a used one?
The AFC lowers the reported frequency.
Its not a scaling of the maf table.
right i just couldnt think of how to say that matt lol.
i recommend the fixed afc, its easier to tune with. the gauge afc is new and i hadnt heard of it until you mentioned it.
call tep and leave a message if they dont answer, Dave will definitely call you back. he gets really busy at times and can take awhile to get back to emails.
