Thread: s/c and turbo
Results 1 to 20 of 28
  1. #1 s/c and turbo
    GT Level Member boothe's Avatar
    Troy, Mo
    Wanting to do a build on my car and ahve heard people doing a supercharger and turbo build what are the benefits of this cons and or thoughts on this kind of build
  2. #2 Re: s/c and turbo
    I've heard it's harder to tune. I think it would be better to just turbo it if that's what you are looking to do.
  3. #3 Re: s/c and turbo
    Omaha, NE
    You will never be able to make a higher horse power twincharged 3800 than you could on either S/C or Turbo alone.
    The S/C rotors become a restriction for the turbo.
  4. #4 Re: s/c and turbo
    Florida
    too bad you cant rig the BBV to open under boost from the turbo. then you can open up and make the BBV larger.
    but like said i think it would be easier to make more power on a turbo alone or a bigger SC. going "twin-charge" as its called isnt as efficient and your adding the extra weight of both systems. also its easier to cool a turbo setup via Air-to-air Intercoolers and larger Air to water. vs trying to squeeze an IC under a SC.
    i think the idea is cool and i would love to do it. but besides being different i dont see a reason for it. if your wanting power there are better ways to get it.
  5. #5 Re: s/c and turbo
    The Boss Iceman6669's Avatar
    Jun 2011
    I have heard it is the heat soak when dual charging that becomes the main problem.
    2011 F-150 Yote powered
  6. #6 Re: s/c and turbo
    Jun 2011
    Detroit, MI
    I would twin turbo it instead
    iLoveSpade
  7. #7 Re: s/c and turbo
    Why?
  8. #8 Re: s/c and turbo
    Bunnell, FL
    ^^^ to get laid. the kid needs all he can get to help out
    I'm a Sex Offender
  9. #9 Re: s/c and turbo
    Troy, Mo
    haha thanks i had heard from a couple of people that the supercharger was awesome when it comes to launching then when the turbo spools it takes off but if the supercharger is like a restrictore ill just plan on the turbo set up and sell the rest for some extra cash
  10. #10 Re: s/c and turbo
    utah
    Single turbo, twins are dumb. Turbo and buy a trans
  11. #11 Re: s/c and turbo
    Jun 2011
    Detroit, MI
    Why?
    Cuz I like TT's bro.
    iLoveSpade
  12. #12 Re: s/c and turbo
    utah
    You like have to buy two of everything? You like the weight? You like having to tune the damn things worrying about spool sync....big single>tt anyday
  13. #13 Re: s/c and turbo
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by boothe View Post
    A properly sized turbo wont have much lag
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  14. #14 Re: s/c and turbo
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    supra?
  15. #15 Re: s/c and turbo
    Bunnell, FL
    actually the perfect setup is a small and large turbo. just a pain to deal w/
    the small one spools faster so you can boost sooner and the large can push the numbers extremely high
    I'm a Sex Offender
  16. #16 Re: s/c and turbo
    SWPA
    Quote Originally Posted by boostedcompg View Post
    Do you even know what you are talking about? Spool sync? What the hell?
    Also 2 smaller turbos is much more streetable than one big ass turbo.
  17. #17 Re: s/c and turbo
    Jan 1970
    Maquoketa, Iowa
    The sc does not become a restriction. You just have a lot more to deal with, ideally an a/a intercooler, a a/w intercooler, a supercharger, a turbo is hard to fit, costs more and you have a couple more points of possible failure. Really the turbo lag saves the trans most of the time.
  18. #18 Re: s/c and turbo
    SE Level Member BlackGS's Avatar
    Central Jersey
    The supercharger is not a restriction. Twin-charged is a better option for the street, and will perform equally or better at the track depending on the setup. When done right, there is zero lag anywhere in the rpm and gear ranges. The power is always constant and never lets up in the higher ranges.
    It will be more expensive and complicated to install, but will not require any more or different tuning than turbo only. I run a full water-air intercooler setup which I think performs better on the street. I have a core after the turbo, and another core under the supercharger.
    The primary reason to go twin-charged is to run a larger turbo like a 70 or 72. Running anything smaller defeats the purpose of the supercharger as the lag will probably be acceptable. If you want a low 11's or 10 second car that performs on the street, you might consider twin-charging. Of course, at that level you will need a fully built trans with 1" chain, so consider that in the budget.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  19. #19 Re: s/c and turbo
    SWPA
    If you are looking for flat out horsepower and speed turbo, and turbo alone is the way to go.
  20. #20 Re: s/c and turbo
    Florida
    Black, wouldn't a small turbo have less lag?
  1. Cam for before and after turbo?
    By Zak97GT in forum General Tech Discussion
    Last Post: 03-23-2011, 04:26 PM
  2. going turbo
    By jakedidi in forum Turbo
    Last Post: 02-07-2011, 08:23 PM
  3. which turbo
    By adsgp09 in forum Turbo
    Last Post: 01-03-2009, 06:28 PM
