Thread: s/c and turbo
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: s/c and turbo
    Minnesota
    A properly setup sequential twin turbo system is what the above person was probably talking about. Instead of having two turbos running at the same time you have a smaller turbo for the lower spool and bigger for the higher end.
    As far as twin charging it's like anything else. You can do it correctly and make good power.
    There are cars that make crazy power twin charged. Obviously the setups are different but still they are twincharged. I just don't think people take the time to fine tune or work the kinks out and quit.
    This is not a 3800 obviously but it's twincharged:
    Zenvo Automotive
    1104 BHP and 1430 nm of torque isn't too bad. lol
  2. #22 Re: s/c and turbo
    Feb 2009
    flintnasty MI
    Twin-charged is a better option for the street,
    No thanks.
    I had enough trouble keeping it on the ground from a 70 roll on, a supercharger is not going to add traction.
  3. #23 Re: s/c and turbo
    SE Level Member BlackGS's Avatar
    Central Jersey
    No thanks.
    That's for sure. I've spun at 70 too many times as well.
    I believe the fastest GP that wasn't modified to be an all-out race car is still Zoomer's twin-charged setup that went into the 9's. As said, if you do it right, you will make more than enough power.
    A small turbo is still good for 11's or 12's in street trim, so there is not much reason to add the complexity of twin-charging, unless you want to try something different. I already had everything I needed to go twin-charged except for the turbo and hot-side pipes. I wouldn't go back to turbo only.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  4. #24 Re: s/c and turbo
    GT Level Member boothe's Avatar
    Troy, Mo
    u guys are awesome i will wiegh my pros and cons planning on doing a build in the summer as soon as i get back from over seas.... so wanted to get the info on all of it thanks alot
  5. #25 Re: s/c and turbo
    mi
    can be made to work just overly complicated imo
    Need2Speed Fastest six speed Shelby in the world! - YouTube
  6. #26 Re: s/c and turbo
    Feb 2009
    flintnasty MI
    has nothing to do with overcomplicated, its just pointless really. You need a few tricks but its not anything that cant be done in a few hours, for basically free.
  7. #27 Re: s/c and turbo
    Texas
    If you can't hit 11's or 12's on a turbo alone you are doing something wrong.
    85 Corvette
    01 TA
    03 Z06
  8. #28 Re: s/c and turbo
    Feb 2009
    flintnasty MI
    Quote Originally Posted by txslow6 View Post
    you meant if you cant hit 9s with turbo alone you are doing something wrong.
  1. Cam for before and after turbo?
    By Zak97GT in forum General Tech Discussion
    Last Post: 03-23-2011, 04:26 PM
  2. going turbo
    By jakedidi in forum Turbo
    Last Post: 02-07-2011, 08:23 PM
  3. which turbo
    By adsgp09 in forum Turbo
    Last Post: 01-03-2009, 06:28 PM
