Thread: s/c and turbo
Results 1 to 20 of 28
  1. #1 Re: s/c and turbo
    SWPA
    Quote Originally Posted by boostedcompg View Post
    You like have to buy two of everything? You like the weight? You like having to tune the damn things worrying about spool sync....big single>tt anyday
    Do you even know what you are talking about? Spool sync? What the hell?
    Also 2 smaller turbos is much more streetable than one big ass turbo.
  2. #2 Re: s/c and turbo
    Jan 1970
    Maquoketa, Iowa
    The sc does not become a restriction. You just have a lot more to deal with, ideally an a/a intercooler, a a/w intercooler, a supercharger, a turbo is hard to fit, costs more and you have a couple more points of possible failure. Really the turbo lag saves the trans most of the time.
  3. #3 Re: s/c and turbo
    SE Level Member BlackGS's Avatar
    Central Jersey
    The supercharger is not a restriction. Twin-charged is a better option for the street, and will perform equally or better at the track depending on the setup. When done right, there is zero lag anywhere in the rpm and gear ranges. The power is always constant and never lets up in the higher ranges.
    It will be more expensive and complicated to install, but will not require any more or different tuning than turbo only. I run a full water-air intercooler setup which I think performs better on the street. I have a core after the turbo, and another core under the supercharger.
    The primary reason to go twin-charged is to run a larger turbo like a 70 or 72. Running anything smaller defeats the purpose of the supercharger as the lag will probably be acceptable. If you want a low 11's or 10 second car that performs on the street, you might consider twin-charging. Of course, at that level you will need a fully built trans with 1" chain, so consider that in the budget.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  4. #4 Re: s/c and turbo
    SWPA
    If you are looking for flat out horsepower and speed turbo, and turbo alone is the way to go.
  1. Cam for before and after turbo?
    By Zak97GT in forum General Tech Discussion
    Last Post: 03-23-2011, 04:26 PM
  2. going turbo
    By jakedidi in forum Turbo
    Last Post: 02-07-2011, 08:23 PM
  3. which turbo
    By adsgp09 in forum Turbo
    Last Post: 01-03-2009, 06:28 PM
