Thread: ....you know what it is... 700whp build
Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 274
  1. #1 Re: ....you know what it is... 700whp build
    Just saying that 700whp could be done with a T67, and no spool valve.
    You need to build a turbo car for me.
    Just sayin'
  2. #2 Re: ....you know what it is... 700whp build
    Feb 2009
    flintnasty MI
    Just sayin'
    I do work for people on occasion.
    I guess I failed to mention I was looking to hit 700 on under 22psi.
    A T76 is NOT the turbo to do "low boost power" on, as you are really not even moving into the efficiency range at "low boost". Based on what I have observed on a stock head 3800, you would probably need to be at 30psi to see peak efficiency out of a t76. Every psi I add past 20 adds huge WHP each step up.
    Doing 700whp under 22psi is most likely not going to be possible without some tricks, but you should be able to do mid 600s without much issue. Manuals are cake to make power on a dyno with.
    Damn! Link to vehicle info and pics?
    Its a grudge car, so nobody really knows about it. Me posting about it on here wont get around.
    Its little brother has some videos....
    YouTube - Turbo LS1 Camaro Vs Turbo Toyota Supra Race - Payso Productions
  3. #3 Re: ....you know what it is... 700whp build
    GTX Level Member real diehl's Avatar
    Salina, KS
    Sooooo any updates?
    signature removed for inappropriate content.
    -bio
  4. #4 Re: ....you know what it is... 700whp build
    Donating Users Tengis's Avatar
    Houston
    Do 700whp with an auto and Ill be impressed. Ill guess Ill be impressing myself this year.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  5. #5 Re: ....you know what it is... 700whp build
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    And fwiw there will be 30psi+ dyno runs
    And again, no this car will never run 9s or anything close, 10s should be possible, but my traps will be awsome
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  6. #6 Re: ....you know what it is... 700whp build
    Norristown, PA
    I don't understand a word in this thread but I love it.
  7. #7 Re: ....you know what it is... 700whp build
    Donating Users Dboy23's Avatar
    Aug 2008
    Michigan
    Quote Originally Posted by rocafella2032 View Post
    x2 subscribed
    *sig is too tall*
  8. #8 Re: ....you know what it is... 700whp build
    Jan 1970
    Maquoketa, Iowa
    I just want to see a build list or some pics, I like the ideas and respect the amount of work your putting into these cars, but all your listing is some HP numbers and a few short vids that don't tell us anything. I would like to see what fuel system your using, what works/what didn't work or what's limiting you. If you described a bit more it wouldn't seem so unreasonable numbers you're putting up.
  9. #9 Re: ....you know what it is... 700whp build
    Feb 2010
    Quote Originally Posted by FoSHO99 View Post
    94 octane, alky injection (m10 nozzle) racetronix FP and rewire, 65# injectors, my IPW was at 20ms or about 97% duty cyle IIRC,the fuel pressure was not 100% keeping up, so im going dual pump i the tank this year most likely
    the cam is a 224 224 .574/.566 114lsa, it broke my stock heads 2x's as well as broke a valve spring on 1 cylinder and cracked a intense pushrod
    i had a spec stage 3+ clutch, it slipped got to replacements, still slipped, went stage 4, it slipped right away aswell.
    went with bully and it held for the most part until about 6300rpms so thats why i went triple disc
    the car was running a 3" dp and cutout that freed up 60+whp, aswell as a custom rear manifold, front power log that cracked manyof times,
    intake runners wer removed and had an hv3 at the dyno tme,
    FWIW i did 403whp on 1.9s and a 2.5" downpipe on 18psi, so my numbers arent to different then an automatic,
    i also own a 04 comp g tha dynoes 581whp auto (with the heads i just put on) and a larger intercooler,, aswell as the 3" downpipe,
    the car isnt near as fast as my 5-speed but can launch better, but 1/4 mile would be about the same IMHO, high 10s on a decent day
  10. #10 Re: ....you know what it is... 700whp build
    damn...you break stuff lol keep it up im waiting for the new #'s
  11. #11 Re: ....you know what it is... 700whp build
    Feb 2009
    flintnasty MI
    The way you talk about running 10s makes me sick..
    You have no idea what it takes.
  12. #12 Re: ....you know what it is... 700whp build
    Its still winter in canada.
  13. #13 Re: ....you know what it is... 700whp build
    Jan 2009
    Tallahassee, FL
    It's always winter in Canada
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  14. #14 Re: ....you know what it is... 700whp build
    Banned Trolling GPF
    Quote Originally Posted by Sandman View Post
    lol
  15. #15 Re: ....you know what it is... 700whp build
    Waukesha, WI
    its always winter in wisconsin too
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  16. #16 Re: ....you know what it is... 700whp build
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    LOL 700 whp on stock heads? And a rediculous over sized turbo and a manual? Please post this over on the other site so we all can lawlz without getting in trouble.....
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  17. #17 Re: ....you know what it is... 700whp build
    Feb 2010
    did i say stock heads? no.
    i have a set of heads from CCH that flow past zzp stage 4 heads
  18. #18 Re: ....you know what it is... 700whp build
    Houston
    Flow numbers dont really mean **** unless they were flowed on the same bench, same settings, etc.
    Satin Purple 97 GTP
  19. #19 Re: ....you know what it is... 700whp build
    Feb 2010
    They have flowed a set of the zzp heads already.
    Why all the hate on the 5speed allthe time? I hope you realize I have an 04 comp g that dynoed 581whp at 21psi through an auto aswell. The heads are now off this car and going onto my red 5-speed car.
  20. #20 Re: ....you know what it is... 700whp build
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    hes hatin kuntzie. id drive ur 5 speed. much funner that our autos
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. New Build
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 08:50 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
