Thread: Thinking of Going Turbo in your GP?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
  1. #1 Thinking of Going Turbo in your GP?
    Texas
    First off let me just say that I’m by no means an expert when it comes turbos. This is just a guide to help you get started and help shed some light in your quest for more power.
    Don’t get the impression that you can slap a turbo kit and automatically make 700whp. You need to be realistic with your goals and as I always say, aim low so there is little to no disappointment.
    What are the major components to the kits on the market?
    Turbo
    Turbo Crossover
    Turbo Downpipe aka upper downpipe
    BOV-Blow off Valve
    Wastegate
    Misc. stuff
    Oil line for turbo (journal bearing)
    Intercooler (optional but recommended)
    Vacuum lines
    Valve cover breather
    Injectors
    Fuel pump (optional but recommended)
    Gaskets
    S/C block off plate if supercharged
    Couplers
    180 tstat
    PCM tune
    Let’s look at the turbo kits available and some of their differences:
    Cartuning
    -Comes with a PT-61 (On center exhaust housing)
    -Wastegate perch is bolted to the rear manifold
    -2.5” stainless steel exhaust from turbo
    -42lb injectors included
    -LT1 MAF
    -PCM included
    *Bolts directly on the car with no modification unless you have a 97 Grand Prix
    If you have a 97 the upper downpipe needs to be modified to clear your ABS. For some extra coin the vendor will do it for you.*
    -Front powerlog from ZZP will bolt to this, but a rear will NOT
    -Cartuning does offer a rear ported exhaust with the #6 primary turned
    ZZP Z3 kit
    -Also known as their budget turbo kit
    -Borg Warner 56mm turbo
    -LT1 MAF
    -Powder coated intake pipes
    -TIG welded 304 stainless steel crossover
    -TIG welded 304 stainless steel 2.5" downpipe
    -PCM included
    -Must have/purchase a TOG lower downpipe or weld in short downpipe
    -rear powerlog will not work
    *If you have a 97 the upper downpipe needs to be modified to clear your ABS. For some extra coin the vendor will do it for you.*
    ZZP Z7 kit
    -Precision Turbo T61 turbo
    -LT1 MAF
    -PCM included
    -Rear powerlog WILL work
    Stattama Kit
    -Also known as I’m the baddest mofo sold
    -T67 turbo
    -Front and Rear 304 stainless powerlogs
    -3 inch 304 stainless downpipe (97 owners will need to remove their ABS system)
    -Intake pipes are powder coated
    -Small diameter brake booster
    -Boost controller included
    -PCM included
    Supporting Mods
    NONE-You can bolt on the kit from any vendor and go
    Coming from a S/C build?
    Headers will NOT work (unless you have some super awesome fab skills and custom making your own kit).
    Aftermarket Downpipe (i.e ZZP 3” dp) will need to be sold pending which kit is purchased.
    Front Powerlog can be used and is a great mod in addition to any turbo kit.
    Rear PEM is perfect for a CT or ZZP Z3 kit.
    Catback exhaust will bolt up to all the kits.
    Cam will depend on which one you have. I always recommend going with a turbo cam, however many have used their XP cam with success.
    1.9 Rockers will work nicely with any turbo kit.
    42# injectors will work, but it’s nice to have some cushion for growth when you are ready to mod further. If you haven’t upgraded over your stock GTP injectors look to 60#, unless considering E85 then move to 80#.
    Throttle body any will work
    LIM will work in stock form however some owners do open it up to allow more flow.
    Intercooler should be sold as it won’t work with the turbo setup. ZZP did make a W2A core that went through the M90 case at one time, but it’s not showing on their website. With that being said some form of intercooler should be considered.
    fuel pump is recommended. If you are looking to go turbo then you should at least consider it.
    PCV will need to be blocked
    M90 blockoff plate will be needed. Basically you remove the snout, take the rotor pack out, and then bolt this to the end of the M90 case.
    M90 block off installed with CT kit:
    Coming from a NA build?
    Cam look to a turbo specific one.
    42# injectors will work, but it’s nice to have some cushion for growth when you are ready to mod further. If you haven’t upgraded over your stock injectors look to 60#, unless considering E85 then move to 80#.
    HVII/III work nicely with any turbo kit.
    PCV will need to be blocked.
    L36 topswap with CT KIT
    Additional “Mods”
    Boost Controller-No longer will you have to change wastegate springs to adjust how much boost you are pushing. Prices vary depending where you purchase.
    A2A Intercooler-Cooler IAT=better tuning, increased power, increased boost can be purchased through a vendor or make your own using ebay.
    Turbo Blanket-Keeps underhood temps down.
    Nitrous-Nice way to cool the intake charge and would only require a tiny “pill” to accomplish.
    Methanol-People have used with good success
    Turbo Timer-Yes you can use them, but you can also just drive normally before you arrive to your destination, then leave it running for 20-30 seconds in the parking lot.
    IC Spray bar I’ve seen mixed reviews. You can purchase them or build your own.
    Tuning-The vendor's PCM are a great way to get started, but it's imperative at some point you do a custom tune tailored to your mods. This will ultimately give you the full benefit of going turbo.
    Real World Results
    N/A L67- 142whp-M90 block off, open cone intake, 2.5" dp, Intense Racing OG PCM, 18" wheels
    TGP- 266whp- 10 PSI, intercooled CT kit PT 61, M90 block off, 2.5" exhaust, 42lb injectors, CT PCM, , L67 MAF, 42lb injectors, 18" wheels
    TGP- 286whp- 11 PSI, Intercooled, CT kit PT 61, M90 block off, plog, 2.5" exhaust, LT1 MAF, ZZP PCM, 42lb injectors, Racetronix fp, 18" wheels
    TGP- 346whp- 12 PSI, Intercooled, CT kit PT 61, M90 block off, plog, 2.5" exhaust, cutout, LT1 MAF, ZZP PCM, 42lb injectors, Racetronix fp, 1.9 rockers, 16" wheels
    OTHER TURBO RESULTS
    Greg Badass http://www.grandprixforums.net/resul...gtp-71448.html
    284.6whp/413.1wtq @ 9.5 psi
    343.3whp/514.4wtq @ 14 psi
    mods-PT61 Intercooled CT KIT, Stattama ST2, L26 Intake, Crow Cam 105#, Manley Retainers, Racetronix Fuel Pump, 60# Injectors, NGK TR6 spark plugs, 180 t-stat, Stock exhaust, Dyno Brian tune
    SepGT2-Other forum
    339.2 WHP/358.6 WTQ @ 13 PSI
    mods-
    ZZP Z7 Turbo Kit Turbonetics 62-1 turbo, 42.5# Injectors, LT1 MAF, 160 tstat, A/A IC, Ceramic 3inch DP and turbo cross over, Tial Blow off valve, 3 inch ZZP SS exhaust, ZZP Resonator, Stock mufflers, 3 inch cutout
    85 Corvette
    01 TA
    03 Z06
  2. #2 Re: Thinking of Going Turbo in your GP?
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    real nice write up man. could could you add the price for each kit though?
  3. #3 Re: Thinking of Going Turbo in your GP?
    Texas
    I didn't add the price because they can change over time. To keep it current I did make each kit name clickable that directs you to the product with pricing.
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: Thinking of Going Turbo in your GP?
    Sticky'd this thread.
    Good read.
  5. #5 Re: Thinking of Going Turbo in your GP?
    May 2008
    Winnipeg, MB
    who on here has the Stattama kit?
    2007 Pontiac Grand Prix
  6. #6 Re: Thinking of Going Turbo in your GP?
    SE Level Member BlackGS's Avatar
    Central Jersey
    I have the Stattama kit in twin-charged configuration, and have been running this on my daily driver for about 4 years now. I'm on the second turbo - the first was a Turbonetics T72, which lasted about 30,000 miles, and now I run a Comp 6765 billet.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  7. #7 Re: Thinking of Going Turbo in your GP?
    Ontario
    This is perfect for me considering my most recent purchase.
  8. #8 Re: Thinking of Going Turbo in your GP?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    so for a 97 the biggest downpipe I can have if I still want ABS is 2.5"?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  9. #9 Re: Thinking of Going Turbo in your GP?
    Texas
    Quote Originally Posted by EJOUIE View Post
    If you want to retain your factory ABS then yes that is correct. If you are feeling froggy enough you could swap to a newer style.
    85 Corvette
    01 TA
    03 Z06
  10. #10 Re: Thinking of Going Turbo in your GP?
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Although not recommended a SC intercooler W/A setup will work if youre using an M90 housing. In some instances it is actually more beneficial because you spool faster and you can do things like adding ice to further cool the air.....but no one does it. For drag racing its better but tend to become heat soaked with prolonged use unless youre using ice or some chemical to further the cooling. Also, you dont lose boost like you do by going thru the A/A FMIC. Long story short, if you already have a SC setup and are modding on a budget your IC setup will work for you. Hell if a full size IC can cool down the blast furnace of a M90 then a turbo should be no sweat. lol
    EDIT: Awesome write up! Also note that you can fit a 3" downpipe in 97 by using a smaller brake booster, it just has to be custom made. Tengis on here had 97 turbo car with this.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  11. #11 Re: Thinking of Going Turbo in your GP?
    Central Jersey
    Quote Originally Posted by t24moore View Post
    I ran this way for a while when I first installed the turbo. If tuned right, it will support up to about 15psi (I ran mid 12's @110 on pump gas). I have since installed another w/a core after the turbo.
  12. #12 Re: Thinking of Going Turbo in your GP?
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Where can I get my hands on a LT1, LS1 TB+ MAF set up for my turbo set up?
    '04 MC Intimidator SS,'96 Camaro Z28 ,'98 GTP 12.9 trap
    '93 383 stroked Trans am (Crashed),
    '93 Chevy c1500 Pickup Indy500 Special edition,
    '01 VW GTI Garrett 50 trim, '98 GTX clone (Current car) Working on Top swap!
    Ohio
    Why do you need it?
  14. #14 Re: Thinking of Going Turbo in your GP?
    Round lake, IL
    My TB and maf are toasted and with my turbo set up I would like to get a better TB+MAF
    Ohio
    Just stick with a 99 l67 tb and maf. Unless you need the space from an ls1
  16. #16 Re: Thinking of Going Turbo in your GP?
    Texas
    Quote Originally Posted by deadsnake View Post
    Ported factory TB is all you need. The MAF you would be better off going with an external such as a LT1 (complete plug and play) unless you get a modified MAF for your L67 TB that will give you some more wiggle room when upping the boost.
    85 Corvette
    01 TA
    03 Z06
  17. #17 Re: Thinking of Going Turbo in your GP?
    Aug 2012
    San Antonio, TX
    I noticed you put some numbers down for various modification levels, which is awesome. Anyone have any dyno info? If not, when do the various turbos start spooling up?
  18. #18 Re: Thinking of Going Turbo in your GP?
    Texas
    Typically the lower the A/R the faster the turbo will spool. You could always install a nitrous kit to help with spool. Many have used that method with great results. Spraying the nitrous pre turbo.
    85 Corvette
    01 TA
    03 Z06
  19. #19 Re: Thinking of Going Turbo in your GP?
    Kemmerer, Wyoming
    do you get better turbo results with a na or a supercharged? im thinking about buying a newer grand prix to turbo.
  20. #20 Re: Thinking of Going Turbo in your GP?
    Jan 2012
    Philadelphia
    in your opinion was it worth the money to turbo your GP? curious because i have diamond pistons and may possibly go turbo in the "future" depending on how much i like my GenV IC set up.
  1. wife needs a newer car..thinking a mitsu lancer awd turbo?
    By AmericanSoldier in forum Off Topic Discussion
    Last Post: 11-12-2011, 01:00 PM
  2. Thinking about adding a turbo
    By MS1227 in forum Turbo
    Last Post: 12-13-2008, 04:22 PM
  3. Thinking of going turbo. Guess who?
    By TDCRacing in forum General Tech Discussion
    Last Post: 10-14-2008, 03:27 AM
  4. Replies: 24
    Last Post: 06-12-2008, 10:50 AM
