Thread: Thinking of Going Turbo in your GP?
Results 41 to 60 of 62
  1. #41 Re: Thinking of Going Turbo in your GP?
    Quincy, Mass
    im using a ported l67 tb on an l26 intake. with the turbo forcing air into the intake rather than the supercharger trying to suck air in, the tb doesnt need to be bigger. you can use the n*, most use an lt1 maf, im not sure why not the lq4 but it has also been used. both those mafs also have a higher frequency range so you dont need an mini afc.
    No more GP 04 Impala SS Indy:
  2. #42 Re: Thinking of Going Turbo in your GP?
    Kemmerer, Wyoming
    Quote Originally Posted by Swiggles View Post
    are you going to port the upper and lower intake manifolds? supposedly the LQ4 maf will break when used with turbo's, and the LS7 maf is probably really tough to outflow
  3. #43 Re: Thinking of Going Turbo in your GP?
    Quincy, Mass
    The upper I'm not going to port, the l67 tb is a tiny bit smaller already if I remember right and the adapter is a little smaller too. I might bite out the holes a little to line it up better. The lim I gasket matched to the heads but that's all. You'll benefit from smoothing down the channels but i had done so much other stuff that I didn't get to it.
  4. #44 Re: Thinking of Going Turbo in your GP?
    Kemmerer, Wyoming
    I did some digging on the internet and found this article about the cartuning turbo kit. there are pictures at the bottom of the article, and it looks to me like the kit would work with a rear power log. am I right or wrong?
    http://www.hotrod.com/how-to/engine/...ac-grand-prix/
  5. #45 Re: Thinking of Going Turbo in your GP?
    GT Level Member Ifryrice's Avatar
    Jun 2012
    Osceola, IN
    its the front power log's that are the most restrictive
    "America is all about hot, nasty, bad ass speed" Eleanor Roosevelt 1936
  6. #46 Re: Thinking of Going Turbo in your GP?
    Quincy, Mass
    The car tuning kit will work with the new normal rear plog but not the turbo plog. The waste gate attaches to the stock downpipe location on the rear manifold like the z3 kit. You would have to do some fab work to relocate the waste gate in order to use the rear plog.
    Go to cartuning.ca they have clearer pictures of the kit.
    Sent from my iPad using Tapatalk
  7. #47 Re: Thinking of Going Turbo in your GP?
    Kemmerer, Wyoming
    I looked closer at the kit on the car tuning website and I can see that the waste gate bolts to the downpipe, and then has a pipe that goes to the crossover, it does look like the oem rear exhaust manifold is necessary, but it also looks like a flange could be built to interface between the downpipe and crossover to use the rear power log. maybe cut the flange off where the downpipe attaches to the oem rear manifold and weld a v band clamp with a short amount of piping, and a v band on the other side? worth the effort or not?
  8. #48 Re: Thinking of Going Turbo in your GP?
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    I still have the xover, upper DP and lower DP from my CT kit. I wanted to upgrade to the rear turbo plog (new plog wasn't out yet) to open up the exhaust more since I had a rear PEM and needed to help engine breathe. That meant relocating the WG. Which BTW makes it a pain to change the rear plugs with the CT kit.
    I moved the WG to the xover right where the front plog meets the xover and made it an open dump. I then blanked up the flange going to the DP.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  9. #49 Re: Thinking of Going Turbo in your GP?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Amazing thread!!!!
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  10. #50 Re: Thinking of Going Turbo in your GP?
    Kemmerer, Wyoming
    what does an open wastegate do?
  11. #51 Re: Thinking of Going Turbo in your GP?
    hangover park IL
    it gives you another place to shove a gerbil
    ~James~ Psychotic Gearhead
  12. #52 Re: Thinking of Going Turbo in your GP?
    Feb 2008
    NY
    It helps with even flow in the exhaust and reduce turbulence
  13. #53 Re: Thinking of Going Turbo in your GP?
    I'm going to run a L26 with L67 tb
  14. #54 Re: Thinking of Going Turbo in your GP?
    Kemmerer, Wyoming
    Which turbo cam will work best with 130 lb springs. I'm not sure I'm going to change cams, currently have an xp cam, just want to hear people's opinions. The xp cam is at least better than stock for a turbo, right?
  15. #55 Re: Thinking of Going Turbo in your GP?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Look at the vendors recommendations...do you like asking the same question 8 different ways to get the same answer 8 times for everything?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  16. #56 Re: Thinking of Going Turbo in your GP?
    Kemmerer, Wyoming
    Quote Originally Posted by NebTurboST5 View Post
    none of the vendors suggest the 130lb springs. zzp either says 125 for the stattama stage 1 or 140/150 for the stage 4/5, and intense doesn't suggest any particular valve spring. sorry to annoy you with my questions.
  17. #57 Re: Thinking of Going Turbo in your GP?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by SgtMarshal View Post
    for all intensive purposes a 125# spring is basically a 130# spring. i have the crow 125# springs shimmed to 130# seat pressure in my car with an ST5 cam and dont have any issues. i do think that i am getting a little valve float over 6000RPM as my power starts to fall off so heavier springs would be a benefit. but it doesnt mean that you cant run that setup. per your own requirements you said you didnt really want more then 375 at the wheels. 375 can easily be done with your XP cam and about 14-15psi (maybe less) for instance my car made 340 on the stock cam, springs, heads, on 13psi. shouldnt be to hard to pick up another 35HP with an xp cam. no it is not the most efficient setup. i dont think that you will be able to get the same power running significantly less boost with a specific turbo cam. given your power goals i would not switch cams. if you think you want more in the future and are willing to shell out big bucks on a trans in the future then by all means get an ST5. no reason not too.
    i guess maybe i dont understand the question, you shouldnt be picking a cam based on the springs you already own if you are going for an all out setup. you have stated that you arent going for an all out setup, in that case your springs will be more then adequate to safely run any turbo cam on the market...
    if i had it to do all over again...i would pick these things in priority order...
    HOW MUCH POWER I WANTED?
    HOW MUCH LAG I COULD LIVE WITH?
    -those two questions will pick your turbo/cam for you
    -match the springs to the cam
    -match the timing chain to the springs/cam ramp rates
    none of the stattama turbo cams idle poorly
  18. #58 Re: Thinking of Going Turbo in your GP?
    Oct 2017
    Dover TN
    I really like the thread. One question- has anyone rigged up a twin turbo? That is the route I'm thinking of doing on my 2001 GPGT coupe I just was given. Any thoughts on this?
  19. #59 Re: Thinking of Going Turbo in your GP?
    Where the heck would you even put the other turbo?
    It's already at ultra limited space with a single turbo.
    Stick them both out the hood maybe.
  20. #60 Re: Thinking of Going Turbo in your GP?
    Kemmerer, Wyoming
    I saw a rock crawler for sale once, it had a 3800 with twin turbo's. engine bay was huge, really there was no bay with defined firewall's and stuff and with that in mind, there isn't enough space in the grand prix engine bay for 2 turbo's
  1. wife needs a newer car..thinking a mitsu lancer awd turbo?
    By AmericanSoldier in forum Off Topic Discussion
    Last Post: 11-12-2011, 01:00 PM
  2. Thinking about adding a turbo
    By MS1227 in forum Turbo
    Last Post: 12-13-2008, 04:22 PM
  3. Thinking of going turbo. Guess who?
    By TDCRacing in forum General Tech Discussion
    Last Post: 10-14-2008, 03:27 AM
  4. Replies: 24
    Last Post: 06-12-2008, 10:50 AM
