Thread: Thinking about adding a turbo
Results 1 to 7 of 7
  1. #1 Thinking about adding a turbo
    Nov 2008
    Georgia
    I was thinking about adding a turbo to my stock 08 gp base model. I was was wondering how easy this is to do with the zzp z7 kit. Will this kit even work with the '08s? Also what else would be involved parts wise?
    Thanks!
  2. #2 Re: Thinking about adding a turbo
    SE Level Member f0rge's Avatar
    Nov 2008
    toronto
    it's not "easy" but it's not hard either. if you're going to install the kit yourself plan on it taking the whole weekend unless you're a mechanic. the kit should include everything you need.
    not sure about whether the 08 PCM can be tuned, but i'm sure there's a workaround somewhere
    98 GTP - supercharged
    01 GT - turbocharged
  3. #3 Re: Thinking about adding a turbo
    GT Level Member rodman's Avatar
    Apr 2008
    Do the front and rear p log's stainless while your at it
  4. #4 Re: Thinking about adding a turbo
    Oklahoma
    I think the PCM is going to be the issue as I understand it.
  5. #5 Re: Thinking about adding a turbo
    Apr 2008
    after 06 they cant be retuned we all run 05's
  6. #6 Re: Thinking about adding a turbo
    Chicago, IL
    So how does the Z7 turbo for 04+ GP's stack up against the Cartuning turbo or Stattama?
    MSD Ignition Coils, K&N CAI, SLP Headers/Downpipe/High Flo Cat/Cat Back Exhaust, Overkill PCM, 20" Moda Rims
  7. #7 Re: Thinking about adding a turbo
    I live here. UR LOSN's Avatar
    Rockford, IL
    all the bolt up kits are basiclly the same. its just a matter of which brand you preferr. customer support, delivery, kit quality.
    I'd do a search about the pros, and cons of each kit. what people like, and what they dont.
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Thinking of going turbo. Guess who?
    By TDCRacing in forum General Tech Discussion
    Last Post: 10-14-2008, 03:27 AM
  3. adding gauges
    By keenan00gtp in forum Visual/Body Modifications
    Last Post: 10-12-2008, 11:48 PM
  4. Replies: 24
    Last Post: 06-12-2008, 10:50 AM
