Thread: Kinda irritated, is this tire defect or alignment?
Results 1 to 20 of 21
  1. #1 Kinda irritated, is this tire defect or alignment?
    Pennsylvania
    I got my car aligned with new front tires about a year and a half ago. I was planning on replacing the rears this spring because they're about shot. I just took my front wheels off to clean the wheels real good inside the out. Discovered this.
    The rest of the tread is still like brand new, you can even see the markings on the inside of the treads in the middle. Just this inside lip is worn down like this... Im pretty sure it's alignment which makes me feel like I should go back to who did the alignment and show them this. Im lucky I found this, and Im pissed I have to buy a whole new set of tires. This is the driver side, the passenger side is worn down a little but nothing like this one.
    Sport Edition Kv5 18x8
  2. #2 Re: Kinda irritated, is this tire defect or alignment?
    run your hand/fingers over the outer edge there. are the threads cupped? or smooth feeling, both side look like they may be cupped. hard to tell in a pic tho.
    if cupped its alignment.
    or you rubbed a curb hard, like real hard.
  3. #3 Re: Kinda irritated, is this tire defect or alignment?
    Pennsylvania
    That's the inside though, the outside is brand new looking... along with the rest of the tire. I think if I rubbed a curb that hard I'd be buying new wheels, too, lol.
  4. #4 Re: Kinda irritated, is this tire defect or alignment?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    No good going back to the person who did the alignment if it was that long ago. They could blame you hit a pothole or something else to throw it off. Did the front tires looks visibility off? Thats a lot of wear, this is what one of mine looked like after the alignment being off and low air pressure.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: Kinda irritated, is this tire defect or alignment?
    the treads feel smooth? if not theres a alignment issue.
  6. #6 Re: Kinda irritated, is this tire defect or alignment?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    being worn that much more on the inside than outside screams alignment to me.
    04 GTP -HAI, 1.9 rockers.
  7. #7 Re: Kinda irritated, is this tire defect or alignment?
    the more i look at this pic, i see cupping.
  8. #8 Re: Kinda irritated, is this tire defect or alignment?
    Apr 2012
    Dayton, OH
    The left side is up higher from what i can see
    If thats what cupping is called
    Sent from BFE
    2012 F150 STX
  9. #9 Re: Kinda irritated, is this tire defect or alignment?
    Buffalo
    Suspension issues
  10. #10 Re: Kinda irritated, is this tire defect or alignment?
    yup, if you look at the left side two rows the lugs are higher on one side, the right side looks smooth. if you slide your hand over that you'll feel the lip hit your hand one way with the sharp edge, then feel your hand drop over them the other way.
    camber issue i bet.
  11. #11 Re: Kinda irritated, is this tire defect or alignment?
    Apr 2012
    Dayton, OH
    I had those khumos. I hated those tires. Terrible in anything but the dry and wet and they always wore weird but i blame my alignment.
    Sent from BFE
    2012 F150 STX
  12. #12 Re: Kinda irritated, is this tire defect or alignment?
    Pennsylvania
    Well I took it to a guy I know personally that has been doing tires and alignment for longer than I've been alive. He said it looks like the ply in the tires is coming apart, and that it's a defect in the tire... the layers are seperating. He said he'll double check my alignment when I get the new tires.
    Im getting away from the kumhos because as Russo said, I've had 6 of these tires now and they all wore strangely. I was hoping to wait until spring for new tires cause my car is gunna be garaged, but I cant let this go so.. off to tire rack I guess.
    Thanks everyone.
  13. #13 Re: Kinda irritated, is this tire defect or alignment?
    Apr 2012
    Dayton, OH
    I'd get the alignment checked anyway after new tires. Better safe than waste couple hundred in tires.
    Sent from BFE
    2012 F150 STX
  14. #14 Re: Kinda irritated, is this tire defect or alignment?
    Buffalo
    You could have an alignment but
    poor struts - cupping
    Ball joints and tire rod ends - inner and outter wear
    camber issues - same as above
  15. #15 Re: Kinda irritated, is this tire defect or alignment?
    Those tires are almost spent anyway, they have maybe 4/32nds left and are just above the wear bars. You wouldnt make it though winter at all.
    Also, larger than stock rims and tires make the tire wear worse and if you never replace them all at once you can't always do 4 wheel rotations and that lowers tread life.
  16. #16 Re: Kinda irritated, is this tire defect or alignment?
    Thats pretty common to see of W-body cars, I notice it all the time at work even with good alignments.
    That tire isnt cupped it's just worn on the inside because of camber. And some tires don't take well to camber and they do what you see there. Some Firestone tires do it alot, they will seperate a belt near the sidewall and wear smooth and then blow out. We run a factory negative camber and car makers don't care one bit if the tires don't last their full mileage warranty, if the car is within spec it's all that matters to them.
  17. #17 Re: Kinda irritated, is this tire defect or alignment?
    Enfield, CT
    Looks like an alignment issue and over inflation of the tire as well. What PSI are you running in the tire?
  18. #18 Re: Kinda irritated, is this tire defect or alignment?
    Feb 2013
    37.295091, -121.930053
    does this chart help
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  19. #19 Re: Kinda irritated, is this tire defect or alignment?
    gardner,mass
    Alignments can pop out anytime from hitting bumps hard and ****. Or the place that did the alignment was off. CAnt tell you how many times i went to certain places and the alignment was off then went somwhere else and it was dead on after that initial place said it was due to my tires.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  20. #20 Re: Kinda irritated, is this tire defect or alignment?
    Pennsylvania
    Well, Im shopping now... two that caught my eye were Hankook Ventus S1 Noble^2... Ultra High Performance All-Season, scores well all around on Tire Rack reviews are good.
    Goodyear Eagle F1 Asymmetric.. Ultra High Performance All-Season, again really good reviews $700 for a set with a rebate
    Kinda leaning towards the Goodyear.
  1. New (er) Transmission Problems...Irritated.
    By Booba5185 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-12-2014, 08:14 PM
  2. Roof Rails Defect?
    By indygrandprix in forum General Grand Prix Discussion
    Last Post: 09-19-2014, 03:03 PM
  3. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  4. I got irritated today and.....
    By JESSEGOTTA GP GT in forum Tires & Wheels
    Last Post: 02-18-2010, 07:25 PM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
