Thread: lug nut and tire size info needed??
Results 1 to 16 of 16
  1. #1 lug nut and tire size info needed??
    Sep 2013
    Frederick,MD
    i just got a set of 17x7 uni lug rims through a trade.rims are nice,prob not my 1st choice but for now they will be fine.anyway trying to get opinions on what tire size would go best with them...17x7 wheel..stock 04 gtp,was thinkin a 235 55 17? also appears the wheels have a pretty tight fit for nuts,my factory lugs wont fit,they are to "fat",is there a different version of lug nuts for such a application? thanks for any input
  2. #2 Re: lug nut and tire size info needed??
    Mar 2012
    NC
    They make a skinny locking lug nut thing for that type of wheel. Hit up Autozone or Advance and they'll point you in the right direction.
  3. #3 Re: lug nut and tire size info needed??
  4. #4 Re: lug nut and tire size info needed??
    Nov 2012
    Madison
    they're called "tuner" lug nuts.
    steel > 12 x 1.5mm
  5. #5 Re: lug nut and tire size info needed??
    SWPA
    225/55/17 is the tire size you want.
  6. #6 Re: lug nut and tire size info needed??
    Sep 2013
    Frederick,MD
    ill start the search for lug nuts this week at some point! maybe ill look around on amazon in the next few nights...Stealthee..you think the 235 are to wide? thanks for the info
  7. #7 Re: lug nut and tire size info needed??
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I have those slim splined lug nuts and hate em with a passion.
    Either I'm incompetent or something I've snapped half a dozen studs with those aluminum thin splined ones. And not one with regular lugs.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: lug nut and tire size info needed??
    Sep 2013
    Frederick,MD
    ill keep that in mind..your snapping your wheel studs with alum lug nuts? are you using impact gun? i have one of those torque stick things i use with my factory nuts,seems to work well,but it wont work for the new nuts i need,at least i dont think it will..
  9. #9 Re: lug nut and tire size info needed??
    Apr 2012
    Dayton, OH
    I'm guessing they are aluminum, but no I just use a breaker bar. Again its probably user error but i find they like to crossthread.
    I'm the crossthread and break stuff guy tho.
    Sent from BFE
    2012 F150 STX
  10. #10 Re: lug nut and tire size info needed??
    Nov 2012
    Madison
    You have quite a few options if you are willing to spend a few $$.
    I plan on some Mutekis SR48 for my next nuts. Burnt blue or some neo chrome, both about 100 roughly
    Here is an example from Amazon.
    http://www.amazon.com/gp/product/B00...A121OVXF5T1GOJ
  11. #11 Re: lug nut and tire size info needed??
    Sep 2013
    Frederick,MD
    hey spazz thanks for the link...i have a center cap so i can go with something ugly or unsightly! ill look at less expensive versions of the ones your looking at for ideas
  12. #12 Re: lug nut and tire size info needed??
    SWPA
    Quote Originally Posted by ddw350 View Post
    You could probably run 235 width, but 235/55 is 27.1" tall. 235/50 is only 26.25 tall. If you want to go wider you'd want 245/50/17, but 245 is probably a little too wide for a 7" rim.
  13. #13 Re: lug nut and tire size info needed??
    Nov 2012
    Madison
    Ooops forgot about the center cover. Yeah then you have to know what length is right. But make sure they are steel
    These would be perfect. Most are 3/4 drives(19mm)....these are 17mm drive.
    http://www.amazon.com/Gorilla-Automo.../dp/B001O0HOK4
  14. #14 Re: lug nut and tire size info needed??
    Sep 2013
    Frederick,MD
    yea...im gonna need something pretty small in diameter. i havent measured the actual diameter of the holes in the rim yet..ive been looking at the "tuner" style lugs as well,id rather have a regular nut though if all possible...
  15. #15 Re: lug nut and tire size info needed??
    there's two rules for lug nuts if you are an normal car person:
    1) never spline drive
    2) never aluminum
    the rest is all fair game. there are some really, really nice sets out there that will typically cost north of $250/set, but those are completely unnecessary unless you have some super sweet wheels to showcase.
  16. #16 Re: lug nut and tire size info needed??
    Sep 2013
    Frederick,MD
    just measured my actual diameter of the hole for the lug nut in the wheel..its only 7/8 inch in diameter,cant even get a socket in it,looks like ill have to go with the "tuner" style lugs..
  1. Info needed
    By Special K in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2013, 08:14 PM
  2. tire size help needed please
    By asite57 in forum Tires & Wheels
    Last Post: 09-18-2012, 12:23 PM
  3. Info Needed
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2011, 08:03 PM
  4. Tire size help needed!!
    By Pontiacman76 in forum Tires & Wheels
    Last Post: 08-11-2010, 01:57 PM
  5. top swap info needed .
    By PALMCASTER GT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 01:40 PM
