Thread: How to replace a lug nut stud.
Results 1 to 18 of 18
  1. #1 How to replace a lug nut stud.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I need to know how to replace a lugnut stud because I sheared one of the passenger front ones off, here is some ranting back story. So I was taking off the right front wheel of my 01 GP GT and one lugnut was hard to get off, not thinking about it I took the rest of them off. Replaced the quick strut, as i was tightening them, the one lug nut sheared the stud off thus allowing the 4 way I was using too hit me right on the dome. After some cussing and swearing, I remembered I bought aftermarket wheels which came with lugnuts about a year ago. Would the place I bought the wheels from be able to fix this problem for free or be able to help in anyway you think? I know I'm being kinda cheap but I just replaced both front struts/springs, tie rods, 2 new tires because they worn really weird because of bad tie rods. So is fixing the broken stud that easy?
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: How to replace a lug nut stud.
    I think you need to replace the wheel bearing but i'm not positive. You can run with 4 lugs no problem
  3. #3 Re: How to replace a lug nut stud.
    Apr 2012
    Dayton, OH
    I would need more input on this, I mean would it be okay period? I have to go on a trip to Michigan Friday, which is about a 600 miles round trip. I'm about to take it to the stealership or local mechanic just so I have I done before then.
    2012 F150 STX
  4. #4 Re: How to replace a lug nut stud.
    I've driven 5 lug cars on 3 lugs for months with no problems.
  5. #5 Re: How to replace a lug nut stud.
    London Ont, Canada
    I think a new stud can be pressed in, but for time/cost better off just replacing the hub. I mean it is a grand prix, probably needs it done anyways.
  6. #6 Re: How to replace a lug nut stud.
    Apr 2012
    Dayton, OH
    I honestly feel that this post was stupid because I just found out how to replace it googleing for another 10min by basically removing the rotor,caliper and just pounding the stud thru with a Hammer and punch then, pull it thru using another lugnut as a spacer. Me not having air tools means this is going to suck...Found it here seems kinda right.: How do you replace a full length stud on a 1999 Grand Prix front wheel Seems kinda right.
    2012 F150 STX
  7. #7 Re: How to replace a lug nut stud.
    Are you located in troy, OH?
  8. #8 Re: How to replace a lug nut stud.
    Apr 2012
    Dayton, OH
    Yeah
    2012 F150 STX
  9. #9 Re: How to replace a lug nut stud.
    Not very far from me
  10. #10 Re: How to replace a lug nut stud.
    Apr 2012
    Dayton, OH
    tomorrow I'm just going to yell at Tire discounters to try to get the stud fixed for free or reduced cost.
    2012 F150 STX
  11. #11 Re: How to replace a lug nut stud.
    Replacing a stud is super easy.
    Remove all the brake stuff, rotor, caplier etc etc and grab a hammer and chisel or something and pound the stud out, 1 swift smack and it'll come out, then take the new stud and hammer it in from the back.
    Easy as pie and might cost you 3 bucks for a new stud.
    EDIT: seen what you posted about going somewhere to do it, but honestly all you need is a socket set and thats it, its just that easy.
  12. #12 Re: How to replace a lug nut stud.
    Apr 2012
    Dayton, OH
    I need to go their anyway for an alignment and 2 tires so, while I'm their il see what they can do. If they can't do anything il just do it myself.
    2012 F150 STX
  13. #13 Re: How to replace a lug nut stud.
    GT Level Member Beelzeboul's Avatar
    Racine
    man I had a talon that sheared lugnuts like a mofo at first a ford wrench was my preference(Sledge Hammer) but I keep one thing around just for this purpose now
    its a crank from something im not sure total weight about 20-25 lbs used like a battering ram
    ;p
    I'm sorry officer I didnt know I couldn't do that
  14. #14 Re: How to replace a lug nut stud.
    Looks like a crank to me
  15. #15 Re: How to replace a lug nut stud.
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    How To Find If A Wheel Bearing Is Bad - YouTube
    In the video it shows how to change a stud look at it, it may be helpful
  16. #16 Re: How to replace a lug nut stud.
    Racine
    thanx
  17. #17 Re: How to replace a lug nut stud.
    Apr 2012
    Dayton, OH
    Alright I got back from Discount Tire. They did the alignment, and mounted 2 new tires I needed and thew in the stud repair for free. So I'm happy.
    2012 F150 STX
  18. #18 Re: How to replace a lug nut stud.
    Good deal
  1. Stripped stud with lug still attached
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 08-29-2012, 04:31 PM
  2. ARP Head Stud Kit
    By GMR Badass in forum Wanted To Buy - Parts
    Last Post: 02-18-2012, 10:49 PM
  3. Boring but necessary - Stud replacement
    By flash527 in forum General Tech Discussion
    Last Post: 12-03-2010, 10:05 PM
  4. Stud removal
    By TheOtherNick in forum How To Write-Ups/Tech Tips
    Last Post: 01-04-2009, 11:21 PM
  5. &#@$ing Wheel Stud
    By Abrasive in forum The Rant Forum
    Last Post: 04-01-2008, 05:44 PM
