Thread: Need some opinions...
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: Need some opinions...
    at this point instead of spending that much time on it i would bead blast them and get them powdercoated.
  2. #22 Re: Need some opinions...
    Donating User Odi's Avatar
    Chicago South Suburbs
    ^^ this.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Agreed, no matter what u do to them, if they are peeling they meed to be blasted and coated.
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  4. #24 Re: Need some opinions...
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    YES
    nothing else is going to make those curbed rims look any better.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  5. #25 Re: Need some opinions...
    Pennsylvania
    Anyone know if the stock tpms will work with these wheels? Trying to find out before I go for tires so I can buy the sensors ahead of time.
    Sport Edition Kv5 18x8
  6. #26 Re: Need some opinions...
    Pennsylvania
    So, just when I thought I had everything figured out, I test mounted the wheels before I made an appointment for tire mounting. It looks like the hub bore is too small. I only had a tape measure on hand but it looks like the evo 5's are about 2.75" and the stock wheels are closer to 3. I read one thread where it said 73mm is the stock bore, which is right about 2.8".
    So am I like totally finished now or can I fix this, like have it bored out to 73mm?
    This really sucks, lol, one hurdle after another. Im so anxious to get these on, I got 4 new kumho ectsa 4x's out in the garage waiting to go on them already... but I guess Im learning the hard way.
  7. #27 Re: Need some opinions...
    attempt to put them on the car, they fit. lots of people have run evo5's.
  8. #28 Re: Need some opinions...
    Pennsylvania
    I did try to put them on, they wouldnt even go far enough on to thread the lugs more than 1 turn.
    I took the center cap off to see what's happening better and yeah, the hole in the middle of the wheel isnt big enough to go over the hub lip on the car.
    But just a few minutes ago, I had time to relax from earlier and I looked at it more clearly... I noticed part of it doesnt seem to be part of the wheel, and there's writing on it.
    Can these be removed? I can spin them pretty freely in the groove there, but I cant pull them out at all... I tried a prybar a little but I didnt want to go too hard incase it would ruin the wheel.
    Edit: K so with some deeper reading I've figured out that I think that's a hubcentric ring, and the writing on it means diameter 79.5 to diameter 66.5 (I remember that slashed circle symbol as a symbol for diameter in my physics and geometry classes, lol). So, before I go and keep trying to crowbar it out and break something, what is the proper way to remove these? Then I guess I'll need to find a new set to get the proper fitment for myself.
  9. #29 Re: Need some opinions...
    penetrating oil brah. and if theyre aluminium try a heat gun too.
  10. #30 Re: Need some opinions...
  11. #31 Re: Need some opinions...
    Kansas
    Lol when I tried putting mine on, they had the hubcentric rings too. Mine just pulled out, but just man up and get em out.
    If they are metal they are corroded on. If they are plastic they are just a tight fit. Either way: try harder.
  13. #33 Re: Need some opinions...
    mi
    BFH
  14. #34 Re: Need some opinions...
    Pennsylvania
    Well I can spin them pretty effortlessly in whatever channel they're in, like they rotate clockwise and counter clockwise with almost no resistance.
    So I've been pounding on it with a pry bar and they're not even moving. I put more PB on it so Im gunna give it like an hour and go beat on it some more
  15. #35 Re: Need some opinions...
    Pennsylvania
    Got the first one out, I cannot believe what a beating that thing took... since the center cap was out I used a long handle screw driver and a hammer to smash it out from behind. After about 5 minutes of hitting it, it started to budge, then 4 or 5 more solid hits and it came flying out... it was metal btw.
    So I guess I'll repeat this process 3 more times and then contact maybe tire rack tomorrow and see if they can supply me with the right rings so I wont have any wobble.
    Always a learning experience
  16. #36 Re: Need some opinions...
    put them on before you buy rings. the likelihood is that you won't need them.
  17. #37 Re: Need some opinions...
    Houston/Baton Rouge
    Those must have been rusted to the rims. lol
    Crazy
    They are for the aluminum ones, the plastic ones would not be that hard to get out.
    Those have must have been on a nissan or honda or something with that small of a bore. With the OD saying 79.5". You will probably need some new hub rings.
  18. #38 Re: Need some opinions...
    Pennsylvania
    Sittin here getting the tires mounted... One of em is slightly bent on the inside so far, outside isn't noticable lol. One thing after another, should've just bought the kv5s from tire rack and payed a little more. Would've had the hub rings included, no dirt or bent wheels. Oh well he said he's gunna balance it the best he can and I'll see how bad the vibration is.
  19. #39 Re: Need some opinions...
  20. #40 Re: Need some opinions...
    Pennsylvania
    running slightly bent wheels isnt anything new.
    Well yeah I'd imagine not, but whatever.
    I think I might just cut my losses, sell these off for whatever price I can get, and buy a set of kv5's.
    Atleast I learned about hub rings and detailing very neglected wheels, though...
    On the bright side, the tires are great... Kumho Ectsa 4x... going over bumps is really gentle, they're quiet, and so far good grip in the rain.
  1. need opinions..
    By Dragonblaze in forum Off Topic Discussion
    Last Post: 11-04-2010, 01:40 AM
  2. Opinions?
    By SomeDudeAtHome in forum Tires & Wheels
    Last Post: 10-14-2010, 03:17 PM
  3. Need some opinions
    By zildjian102 in forum Visual/Body Modifications
    Last Post: 09-18-2010, 10:23 PM
  4. Opinions?? First serious mod
    By bonerjamz03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 10:14 PM
  5. Opinions on SLP air box.
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-23-2009, 08:54 AM
