Thread: How wide of tires can I run on my 98 GTP?
Results 1 to 10 of 10
  1. #1 How wide of tires can I run on my 98 GTP?
    SE Level Member ajc549FF's Avatar
    Lake Zurich, IL
    Gonna be getting new tires...gonna keep my stock 16 inch rims...how much wider can I go with the tires? I have heard bonneville guys can run 255's.
    98GTP 3.5in tips, headers, fenderwell intake, 180tstat...3.5pulley?
    1984 Four Winns (Boat) 190 Horizon 19ft open bow...new 350 soon! and Thru Hull exhaust!
    03-07 Duramax Diesel next summer after paramedic is finally over!
  2. #2 Re: How wide of tires can I run on my 98 GTP?
    Out West
    305's
  3. #3 Re: How wide of tires can I run on my 98 GTP?
    on a 6.5" wheel? 225's.
    Thats it.
  4. #4 Re: How wide of tires can I run on my 98 GTP?
    Out West
    Thats it.
    Conservative.
    I run 245/50/16. - But they're a little bit fat for the rim. 235/55 is probably as wide as you should go on stock 6.5" width
  5. #5 Re: How wide of tires can I run on my 98 GTP?
    the best choice is the stock size. traction won't really be improved with any wider tires than that because of the way they end up cupping and transferring under load.
  6. #6 Re: How wide of tires can I run on my 98 GTP?
    Quote Originally Posted by Nixon View Post
    Conservative.
    Smart.
    See below:
  7. #7 Re: How wide of tires can I run on my 98 GTP?
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    what about a 255/45/90w on a 17 inch rim?
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  8. #8 Re: How wide of tires can I run on my 98 GTP?
    what width wheel?
    what offset?
    what springs? (how low is it?)
  9. #9 Re: How wide of tires can I run on my 98 GTP?
    stock springs, 35+mm offset 17 by 8 wheel i think
  10. #10 Re: How wide of tires can I run on my 98 GTP?
    I have 235/60's on my stockers.
    Fills the wheel well nicely.
  1. Wide tires
    By monsterjam5000 in forum Tires & Wheels
    Last Post: 03-28-2010, 02:48 PM
  2. wide body
    By gtp40th in forum Visual/Body Modifications
    Last Post: 01-06-2010, 09:14 AM
  3. wide
    By nicksilvergt99 in forum Tires & Wheels
    Last Post: 08-15-2009, 12:51 AM
  4. How wide can i go?
    By Dandude2103 in forum Tires & Wheels
    Last Post: 09-08-2008, 07:19 PM
  5. WIDE tires and rims
    By scoobyydooooooo in forum Tires & Wheels
    Last Post: 03-26-2008, 01:21 PM
