Thread: Got some wheel questions? In here!!
Page 9 of 22 FirstFirst ... 789101119 ... LastLast
Results 161 to 180 of 428
  1. #161 Re: Got some wheel questions? In here!!
  2. #162 Re: Got some wheel questions? In here!!
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    Im supose to buy my coilovers soon, right now im running 235/55/17 on 36+ 8'' bullits, will i rub? if i go with 245/45/17 will i be able to go lower? or ill have to go with 235/55/17?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  3. #163 Re: Got some wheel questions? In here!!
    you should be fine. rolling your fenders might be in your future, but i dont see anything telling me that it will be a no-go setup.
  4. #164 Re: Got some wheel questions? In here!!
    Jul 2010
    Montreal
    whats the tire size needed to tire strech on a 8'' bullits?
  5. #165 Re: Got some wheel questions? In here!!
    stretch how much? you could easily run a 215 wide tire on it, but why would you need to? an 8" wide wheel should be easy to tuck.
  6. #166 Re: Got some wheel questions? In here!!
    Oct 2011
    Puyallup WA
    Anyone have or seen pictures of a 04+ Orange fusion GTP with gunmetal or black 18's...I googled and didn't find anything
    08 G8 GT - exhaust Tune
  7. #167 Re: Got some wheel questions? In here!!
    MA
    just to be clear, what bore is needed to fit?
    SMGPFC Member #9
  8. #168 Re: Got some wheel questions? In here!!
  9. #169 Re: Got some wheel questions? In here!!
    MA
    any smaller than that and the rims wont fit.
    any larger than that, and what happens?
    SMGPFC Member #9
  10. #170 Re: Got some wheel questions? In here!!
    smaller the wheels fit, but they dont fit flush meaning youll have to run a spacer so they the hub of the wheel can sit flush against something.
    bigger doesnt matter, has the potential to need hub rings.
  11. #171 Re: Got some wheel questions? In here!!
    MA
    ill have to do some legit research into hub bore, as i cant wrap my head around this. thanks bio
    SMGPFC Member #9
  12. #172 Re: Got some wheel questions? In here!!
    MA
    Alright I could research this topic all night, if I had the patience, since you'll most likely have the answer sitting on your tongue. I'll just ask. The wheels I'm looking at are 72.6mm hub bore. This is just a matter of some hub centric rings, correct?
    SMGPFC Member #9
  13. #173 Re: Got some wheel questions? In here!!
  14. #174 Re: Got some wheel questions? In here!!
    MA
    Thank bio
    SMGPFC Member #9
  15. #175 Re: Got some wheel questions? In here!!
    Oct 2011
    Puyallup WA
    Anyone got any ideas if a xxr 527 18x8.75 +35 would fit on my comp g...I already have 18's with a higher offset with 235 50 18 rubber so I would be looking to just transfer the rubber over
  17. #177 Re: Got some wheel questions? In here!!
    Oct 2011
    Puyallup WA
    Thanx bio they are a really good price so i might go for it
    They are a good price because they are.an uber cheap wheel. Don't get me wrong, lots of guys run them, but I don't think I would stoop to that level of quality for my own car.
  19. #179 Re: Got some wheel questions? In here!!
    Oct 2011
    Puyallup WA
    Oh really? I didn't relize they where a lower quality wheel...are they lower quality then rota's...I only know about xxr's from the subi crowd I used to be apart of...maybe I should just paint my Borbet's
  1. Wheel Hub Bearing questions?
    By dew1520 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2009, 08:42 PM
  2. Mustang Bullet Wheel questions...
    By Iron Indian in forum Tires & Wheels
    Last Post: 02-23-2009, 08:59 AM
  3. deck & steering wheel control questions from an idiot
    By Autio in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2008, 09:57 PM
  4. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
  5. few questions on bullitt wheel
    By nemesis in forum Tires & Wheels
    Last Post: 06-02-2008, 06:00 AM
