Thread: Got some wheel questions? In here!!
Page 9 of 22 FirstFirst ... 789101119 ... LastLast
Results 161 to 180 of 428
  1. #1 Re: Got some wheel questions? In here!!
    you can get adapters, but normally those will add like 20mm to the offset and require you to shave down your studs. your best bet is to find something like them instead.
    EDIT:
    looked at those wheels....duuuuude. those are mustang cobra wheels. find them off a mustang for way cheaper and they will 100% fit since they are 5x114.3 bolt pattern.
    also, 5x4.5 IS 5x114.3....4.5 inches is 114.3 millimeters....therefore those wheels fit perfectly as is...
    i would, however, suggest you think about the 17x9 instead of the 18x9 because you're going to have fender clearance issues with the offset they are offered in and they are going to stick out regardless of which set you get. food for thought.
  2. #2 Re: Got some wheel questions? In here!!
    SE Level Member widetrack2000's Avatar
    Sep 2011
    St. Louis, Missouri
    Thanks for the quick reply, I appreciate it! Since it's obvious you know more about the fitment of wheels on our cars than I do, let me ask you what I'm sure will sound like a stupid follow up question so please bare with me.
    You suggested I look at going with a 17" over an 18" wheel to eliminate any clearance issues I might run into which won't be a problem since I'm currently running a 17" wheel/tire combo and plan on sticking with that size so we won't have to worry about that part of it.
    Your reply indicated that the Eagle #168's I want are actually Ford Mustang Cobra wheels and it would be cheaper for me (thanks for the tip by the way) to track down a set that way since they have the same 5x114.3 bolt pattern that's compatible with my '00 GP and that's where you completly lost me.
    The link to American Eagle wheel company that I attached to my original posting only sells the Eagle #168 with a 5x4.5 bolt pattern regardless of whether it's a 17" or 18" wheel.
    I'm sure it's quite obvious that my level of expertice or lack there of I should say is very clear to you by now but I don't understand how an Eagle #168 wheel taken from a Ford Mustang Cobra referenced in your reply has a 5x114.3 bolt pattern and that same #168 wheel is only availble with a 5x4.5 when purchased directly through American Eagle?
    Hopefully this is the last stupid question I'll waste your time on but with that being said, I'll thank you in advance for breaking the difference down to me. Once again, thank you for taking the time to help regain my sanity.
  3. #3 Re: Got some wheel questions? In here!!
    the 5x4.5 is measured in inches. 5 lug, 4.5 inch bolt pattern.
    the 5x114.3 is measured in millimeters. 5 lug, 114.3 millimeter bolt pattern.
    4.5 inches = 114.3 millimeters.
    they are the same wheel with the same specs.
  4. #4 Re: Got some wheel questions? In here!!
    Sep 2011
    St. Louis, Missouri
    That's what I get for never paying attention in math class huh?
    lol...
    Thank you!!!
  5. #5 Re: Got some wheel questions? In here!!
    Iowa
    Tried searching and found out the size/offset wheels fit but with a differant size tire than I plan on running. I have a stock 07 GXP I want to put 18x8s on it with a +35 offset and 255/45R18s, I found that 245/45R18s fit but I like the 255s better. So would 255s fit on my car with 18x8s and a +35 offset?
    Thanks
  6. #6 Re: Got some wheel questions? In here!!
  7. #7 Re: Got some wheel questions? In here!!
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    Im supose to buy my coilovers soon, right now im running 235/55/17 on 36+ 8'' bullits, will i rub? if i go with 245/45/17 will i be able to go lower? or ill have to go with 235/55/17?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  8. #8 Re: Got some wheel questions? In here!!
    you should be fine. rolling your fenders might be in your future, but i dont see anything telling me that it will be a no-go setup.
  9. #9 Re: Got some wheel questions? In here!!
    Jul 2010
    Montreal
    whats the tire size needed to tire strech on a 8'' bullits?
  10. #10 Re: Got some wheel questions? In here!!
    stretch how much? you could easily run a 215 wide tire on it, but why would you need to? an 8" wide wheel should be easy to tuck.
  11. #11 Re: Got some wheel questions? In here!!
    Oct 2011
    Puyallup WA
    Anyone have or seen pictures of a 04+ Orange fusion GTP with gunmetal or black 18's...I googled and didn't find anything
    08 G8 GT - exhaust Tune
  12. #12 Re: Got some wheel questions? In here!!
  13. #13 Re: Got some wheel questions? In here!!
    MA
    any smaller than that and the rims wont fit.
    any larger than that, and what happens?
    SMGPFC Member #9
  14. #14 Re: Got some wheel questions? In here!!
    smaller the wheels fit, but they dont fit flush meaning youll have to run a spacer so they the hub of the wheel can sit flush against something.
    bigger doesnt matter, has the potential to need hub rings.
  15. #15 Re: Got some wheel questions? In here!!
    MA
    ill have to do some legit research into hub bore, as i cant wrap my head around this. thanks bio
    SMGPFC Member #9
  16. #16 Re: Got some wheel questions? In here!!
    MA
    Alright I could research this topic all night, if I had the patience, since you'll most likely have the answer sitting on your tongue. I'll just ask. The wheels I'm looking at are 72.6mm hub bore. This is just a matter of some hub centric rings, correct?
    SMGPFC Member #9
  17. #17 Re: Got some wheel questions? In here!!
  18. #18 Re: Got some wheel questions? In here!!
    MA
    Thank bio
    SMGPFC Member #9
  19. #19 Re: Got some wheel questions? In here!!
    Oct 2011
    Puyallup WA
    Anyone got any ideas if a xxr 527 18x8.75 +35 would fit on my comp g...I already have 18's with a higher offset with 235 50 18 rubber so I would be looking to just transfer the rubber over
  1. Wheel Hub Bearing questions?
    By dew1520 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2009, 08:42 PM
  2. Mustang Bullet Wheel questions...
    By Iron Indian in forum Tires & Wheels
    Last Post: 02-23-2009, 08:59 AM
  3. deck & steering wheel control questions from an idiot
    By Autio in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2008, 09:57 PM
  4. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
  5. few questions on bullitt wheel
    By nemesis in forum Tires & Wheels
    Last Post: 06-02-2008, 06:00 AM
