i answered in your thread for you.
Im supose to buy my coilovers soon, right now im running 235/55/17 on 36+ 8'' bullits, will i rub? if i go with 245/45/17 will i be able to go lower? or ill have to go with 235/55/17?
you should be fine. rolling your fenders might be in your future, but i dont see anything telling me that it will be a no-go setup.
whats the tire size needed to tire strech on a 8'' bullits?
stretch how much? you could easily run a 215 wide tire on it, but why would you need to? an 8" wide wheel should be easy to tuck.
Anyone have or seen pictures of a 04+ Orange fusion GTP with gunmetal or black 18's...I googled and didn't find anything
just to be clear, what bore is needed to fit?
70.3mm, which is what most aftermarket wheels are.
any smaller than that and the rims wont fit.
any larger than that, and what happens?
smaller the wheels fit, but they dont fit flush meaning youll have to run a spacer so they the hub of the wheel can sit flush against something.
bigger doesnt matter, has the potential to need hub rings.
ill have to do some legit research into hub bore, as i cant wrap my head around this. thanks bio
Alright I could research this topic all night, if I had the patience, since you'll most likely have the answer sitting on your tongue. I'll just ask. The wheels I'm looking at are 72.6mm hub bore. This is just a matter of some hub centric rings, correct?
correct, they'll be fine.
Thank bio
Anyone got any ideas if a xxr 527 18x8.75 +35 would fit on my comp g...I already have 18's with a higher offset with 235 50 18 rubber so I would be looking to just transfer the rubber over
Should fit well.
Thanx bio they are a really good price so i might go for it
They are a good price because they are.an uber cheap wheel. Don't get me wrong, lots of guys run them, but I don't think I would stoop to that level of quality for my own car.
Oh really? I didn't relize they where a lower quality wheel...are they lower quality then rota's...I only know about xxr's from the subi crowd I used to be apart of...maybe I should just paint my Borbet's
Rotas are much better quality.
