Thread: Got some wheel questions? In here!!
Page 7 of 22 FirstFirst ... 5678917 ... LastLast
Results 121 to 140 of 428
  1. #121 Re: Got some wheel questions? In here!!
    well, let me shed some light on your situation.
    1" away from the fender is A LOT. hydroplaning also won't happen unless you get unlucky. those tires aren't too wide.
  2. #122 Re: Got some wheel questions? In here!!
    1" is how I'm sitting now with stock wheels.
    With just a tad under 2* of camber.
    IIRC around 1.7-1.8*
  3. #123 Re: Got some wheel questions? In here!!
    how are you so close to the fenders on stockers? youre not running spacers, are you?
  4. #124 Re: Got some wheel questions? In here!!
    I am 1.1" away in the front, and 1.5" away in the rear.
    the wheel/tire combo I want to run would be 0.9 further out.
    so 0.2" in the front, 0.6" in the rear.
  5. #125 Re: Got some wheel questions? In here!!
    Donating User Odi's Avatar
    Chicago South Suburbs
    ur gonna look like a 4x4 anyways with ur "my vogtlands didnt drop cuz i run bilsteins" mod.
    id say get +35, even with the 255 tire you shouldnt be rubbing with ur current spring/shock setup.
  6. #126 Re: Got some wheel questions? In here!!
    I love the 4x4 mod.
  7. #127 Re: Got some wheel questions? In here!!
    is there any chance these will fit, i dought it but its a shot, they look kinda nice
    18" Scion TC Wheels
    and just found these, i like the black ones the best
    http://greensboro.craigslist.org/pts/2382872830.html
    SMGPFC Member #10
  8. #128 Re: Got some wheel questions? In here!!
  9. #129 Re: Got some wheel questions? In here!!
    May 2011
    Toronto
    Does anyone have a recommendation on what black rims will fit on a 2006 Grand Prix GXP?
    I want all black preferably without a chrome lip or anything. Perhaps something in a 5 spoke design like the stock GXP rims?
  10. #130 Re: Got some wheel questions? In here!!
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Check wheelsnext.com. You should find some great ideas.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  11. #131 Re: Got some wheel questions? In here!!
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    I'm looking to put some 18x9's on. (5x114) Here's a link;
    http://www.customwheelsexpress.com/american-racing-nova-vn701-701-machined-black-custom-rims-wheels-p-130.html?id=18
    Would it be better to go with a 35 or 45 offset?
  12. #132 Re: Got some wheel questions? In here!!
    35 would look better, but 45 would have less chance of rubbing. however, both sets are pretty wide. why are you wanting to go so wide?
  13. #133 Re: Got some wheel questions? In here!!
    Apr 2011
    St. Louis
    Wide because of increased handling and limited options on the ar wheels.
    Are the stock wheels 6.5" wide? What would you recommend as far as width on 18" wheels?
    Would I run into trouble with the fenders?
  14. #134 Re: Got some wheel questions? In here!!
    i would recommend an 8" wide wheel since you'll never need the traction of a 9" wide wheel since you cant even run tires big enough without fender work. however, fender work is most likely going to happen if you get 9" wide wheels.
  15. #135 Re: Got some wheel questions? In here!!
    Apr 2011
    St. Louis
    Okay, and 8" shouldn't rub the fender?
    Would a 17" by 8" with 0 offset work? I don't think these wheels i'm looking at are going to work.
  16. #136 Re: Got some wheel questions? In here!!
    no, zero offset is WAY too low. you need something in the +40mm area for offset.
  17. #137 Re: Got some wheel questions? In here!!
    Do you have any mods to improve the rest of the suspension?
    Also if handling is a concern, you want the lightest wheel/tire combo.
  18. #138 Re: Got some wheel questions? In here!!
    Apr 2011
    St. Louis
    Bummer, the 17x8's only come with 0 offset. Thanks for the help bio, i appreciate it.
    No suspension mods atm. The ar nova wheels are pretty light, the 18"s are in the 25 lb. range.
  19. #139 Re: Got some wheel questions? In here!!
    if they're not under 20, they're not light.
  20. #140 Re: Got some wheel questions? In here!!
    SE Level Member GrandZero's Avatar
    ohio
    Has anyone tryed the wheels from a charger on a 04 plus grand prix?
  1. Wheel Hub Bearing questions?
    By dew1520 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2009, 08:42 PM
  2. Mustang Bullet Wheel questions...
    By Iron Indian in forum Tires & Wheels
    Last Post: 02-23-2009, 08:59 AM
  3. deck & steering wheel control questions from an idiot
    By Autio in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2008, 09:57 PM
  4. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
  5. few questions on bullitt wheel
    By nemesis in forum Tires & Wheels
    Last Post: 06-02-2008, 06:00 AM
