Pretty clear you have no idea what you are talking about and are butthurt you got kicked off ClubGP.
Your 3rd sentence and last sentence directly contradict each other.
And again you use the tactic of "I do like your tactic of: You tell your opinion, then I tell mine, then you tell me I am acting like I know everything." lol
I guess you cant answer any questions, then.
Again. Where am I wrong?
Ok, I guess I am posting to a slow one.
How do you explain that Dorman parts that are labeled WBS show up to the consumer?
How do you explain parts that I received were stamped ZZP?
How do you explain the fact that ZZP parts show up in WBS boxes?
What parts do Mike at WBS manufacture? It says on the website that he ia a manufacturer.
I will let you catch up
I am not going to retype all the answers so here:
This thread is about headers but companies also do this all the time. ZZP does this will their fuel filters without naming their source. This does nothing to prove your point.
See above.
Are you under the impression that to “manufacture” a part you have to build it with your own hands? Do you know for a fact he doesn't?
If you want the last word you can have it. My points and information have been repeated many times over.
WBS headers are just a cheaper knockoff version of ZZP headers with outsourced less expensive parts but still perform just fine.
You have no idea how they perform because you have zero knowledge about header engineering.
how come COMP cams rocker bolts are H&K grade 8 allen head capscrew bolts if COMPETITION CAMS doesnt make em in house?
because they took the time to find a supplier, put the research into the correct dimensions/strength, and bought off the shelf parts from a reliable supplier to sell as their own since they dont have the manufacturing facilities to make their own bolts...but wish to expand their product line.... its call a buisness supply chain....you can get **** cheaper if you bypass the middle men....
you sure as hell dont chose gas stations by the sign that says "we use sweet crude from texas to refine into your fuel vs that evil alberta sands crude..."
its called business
why does zzp charge you nearly 3 times the cost for a mazda millenia heater core made by ready-aire?!? sooo why does zzp paint ZZP on it if they dont make it?!?!
it may be that its cheaper for mike to use an existing supply chain to fill orders, he may have a deal with zoomer....who knows....they did used to be at each others throats and nowadays everything is all hunky dory...
i got used valvecovers from someone in a ZZP box....**** zzp shoulda cleaned em off a lil better
how about you explain to me why zzp modifies and machines a LIM for an IC core...then ships it out with metal shavings inside it even though its "clean"
as i posted in the header thread. he makes the wbs IC as well as the WBS beltwrap. i know ron vogel used to make his mod'd rails and WBS/RVR LCA's
zzp & Pacesetters > all
Trying to answer a question with, 'probably", "maybe, "might', isn't answering the question!
You don't understand that
for turbo:
you're right. ZZP doesn't manufacture all of their stuff either!
hahaha! True story.
so.. what does that have to do with WBS?
Example.
Yo walk into WalMart to buy cereal. WalMart doesn't say they make that cereal. It says, "Kelloggs" in big letters across the front. Why? Because the manufacturer of that cereal wants people to know who made it.
WalMart also has private label items. They are made by a company that WalMart chooses, then they have a WalMart logo slapped on it.
BUT....Here is the difference. The manufacturer of that cereal IS NOTED ON EVERY BOX.
Whether it is cereal, milk, corn chips, etc.
Private label is private label, but WalMart doesn't claim to be a manufacturer, they are a retailer.
Comp Cams question.
1) The cams that ZZP sells are noted that they are indeed, Comp Cams.
2) There is a difference in Comp Cams hiring a third party to MANUFACTURE them for Comp Cams. That's what you are talking about. Somewhere, whether on Comp Cams website, or on the box, will show exactly where they are made.
BUT....here is the difference. When you buy a good or service from WBS, you, at that point, have a contract with WBS. Not with ZZP, not with Comp Cams. You have a right to know where that product originated from. Comp Cams wouldn't have to tell you ****. You didn't buy from them.
It is a business transaction, or a contract. Why the Hell do you think you get a receipt?
If WBS has headers that they say are manufactured by WBS, then they should be manufactured by WBS.
That is the difference
Stealth - RIGHT!
BINGO!
why would the thread be locked?
afraid of the truth getting out?
