I had not heard of a case learn before. I did some searches and other places I'm reading that you need to do a case learn if you are replacing the CPS. Is that correct? From what I read on this how-to and Bill's most recent post, it sounds like not really. Can anyone clear this up and also explain more in-depth what a case learn is? (a link to a good explanation is fine too)
Current symptoms: Car has been having issue where it may or may not hesitate while driving down the road. If it does hesitate, car runs uneven and jerks slightly, then recovers within a few seconds, then a few moments later the tach drops to 0, then about 10-30 seconds later the traction control off light comes on. Car continues to drive fine and when I shut it off and turn it on again, the tach works and the traction light is off indicating everything is fine. It's been doing this for a couple years, but it seems to be happening more often, and looking online it seems this is classic indications to replace the CPS, so I was planning on doing that tomorrow.
Car: 2000 Pontiac GT
