Thread: Can I delete traction control in the pcm file?
Results 1 to 15 of 15
  1. #1 Can I delete traction control in the pcm file?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I know.. strange question. I was dorking around in the blue turd yesterday and decided to just floor it from a dead stop. Of course it didn't hook but I didn't care. When I got home I noticed on the scan log that I saw a solid 13-15 degrees of KR on just on the launch (wheels were spinning). Then it hooked and I went on with my day. No other real KR when I go wide open, just on the launch.
    Now. The interior is gone except for a driver and passenger seat. Center console gone, everything. So that means the traction control button is gone. Is that KR that I got from launching caused by traction control? My low trac light didn't come on either (is that because the button is gone?). Nothing else was knocking around, just the tires spinning.
    I have since put the traction button back but I didn't have time to test it again while its turned off.
    I know i could just pull the ABS fuse but that's not what I'm trying to accomplish. I'm assuming there some table in the bin (DHP) that is for torque management? I wasn't sure what/where to change it.
    Any ideas?
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  2. #2 Re: Can I delete traction control in the pcm file?
    iirc ive seen some thing in my 98 regal file. it may have been tt too. no idea where it was tho, trans file is my guess.
  3. #3 Re: Can I delete traction control in the pcm file?
    just looked in TT, in fuel, looks like it kills the injectors.
  4. #4 Re: Can I delete traction control in the pcm file?
    Torque management is what gave you the kr
  5. #5 Re: Can I delete traction control in the pcm file?
    Kemmerer, Wyoming
    is that a good thing? or can torque management be safely disabled to reduce the kr?
  6. #6 Re: Can I delete traction control in the pcm file?
    Aug 2011
    Gahanna, Ohio
    Hmm so the traction on/off wouldn't have anything to do with it? I know normally if you spin the tires the car would pull timing. But since I didn't have the on/off switch does that disable traction control? I didn't see any low track or any other idiot lights came up and it didn't pull any timing.
    So back to the torque management.. anything specifically in there I can look for? I don't have my laptop with me so I'll dork around with it when I get home.
  7. #7 Re: Can I delete traction control in the pcm file?
    Aug 2011
    Gahanna, Ohio
    Quote Originally Posted by SgtMarshal View Post
    Yes, most tuners get rid of all the torque management settings or lower it so reduce the KR.
    I just can't remember where in the bin I need to change/delete the settings.
  8. #8 Re: Can I delete traction control in the pcm file?
    tm is in the tranny file.
  9. #9 Re: Can I delete traction control in the pcm file?
    Kemmerer, Wyoming
    Quote Originally Posted by buck531 View Post
    my tune has been done by overkill and I can see my torque management have been changed, but that's about all I can understand. if you were using hp tuners I could tell you where the table is, but I'm not sure with dhp.
  10. #10 Re: Can I delete traction control in the pcm file?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    from the Webracin DHP tuning guide:
    In the CALIBRATION DATA > FUEL > TORQUE MGMT folder: - Torque Abuse A/F - change it to 11.7
    - Torque Abuse Differential Score A/F - change it to 11.7
    - Traction Control Desired A/F - change all cells to 11.7
    - Torque Abuse Drive Injector Disable - change it to 0
    - Torque Differential Score Injector Disable - change it to 0 - Traction Disable Injectors - change all cells to 0
    - Disable All Injectors High MPH - change all cells to 255 - Disable 1 Injector High MPH - change it to 255
    - Disable 2 Injector High MPH - change it to 255
    - High RPM PN Fuel Cutoff:
    High Threshold: change it to 4005 RPM Low Threshold: change it to 4000 RPM
    - High RPM Rev Fuel Cutoff:
    High Threshold: change it to 3505 RPM
    Low Threshold: change it to 3500 RPM - High RPM Fuel Cutoff:
    High Threshold: change it to 7005 RPM
    Low Threshold: change it to 7000 RPM
    In the CALIBRATION DATA > SPARK > TORQUE MGMT folder: - Torque Abuse Spark - change it to 0
    - Traction Spark Retard:
    TCSMode1- changeitto0 TCSMode2- changeitto0 TCSMode3- changeitto0 TCSMode4- changeitto1 TCSMode5- changeitto2 TCSMode6- changeitto3 TCSMode7- changeitto4
    - Traction Extra Spark Retard: change all cells to 0
    - Torque Differential Score Retard - change it to 4
    - Torque Abuse Speed Enable - leave at stock setting
    -Torque Abuse Throttle Enable - leave at stock setting
    -Torque Abuse RPM Enable - leave at stock setting
    -Torque Abuse Time Enable - leave at stock setting
    -Torque Abuse Spark Retard - leave at stock setting
    -Torque Abuse Differential Score MPH Enable - leave at stock setting
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  11. #11 Re: Can I delete traction control in the pcm file?
    Dec 2013
    ohio
    13 to 15 degrees of KR. What does it take to chip a piston? I saw 3.2 degrees shifting into third and I was worried. I have traction control disabled and have done monster burn outs never saw any KR.
  12. #12 Re: Can I delete traction control in the pcm file?
    Aug 2011
    Gahanna, Ohio
    Quote Originally Posted by mguzzo View Post
    Thanks man. That's what I was looking for. Guess I'll fire up the lappy386 tonight and change some stuff .
  13. #13 Re: Can I delete traction control in the pcm file?
    Aug 2011
    Gahanna, Ohio
    Well I disabled the above that Mguzzo posted but still is happening. I went to the track today to get a couple full passes but it didn't go well. Here's a screen shot of the launch/KR.
    I know my a/f (EGR) is super rich and that's fine. I'll deal with that later. I just fixed an exhaust leak on the header and it spiked lean and didn't compensate for it. On the burnout I got about 13-14 degrees of KR still. I was going to change the plugs (random misfires) but couldn't find my gapper anywhere.
    Any other ideas? I know I'm missing something.. somewhere.
  14. #14 Re: Can I delete traction control in the pcm file?
    you got a lot of misfires, all the kr is at low rpms too. stops at 4200. whats up with the misfires? you sure you got the plug wires on right. its esy enough to mix two up and it will run pretty good.
  15. #15 Re: Can I delete traction control in the pcm file?
    Aug 2011
    Gahanna, Ohio
    They're on right. I had another set of plugs at home but didn't put them in. I haven't scanned the car since I posted this.
    I ended up fixing it. DOHCZ34(chris) changed a bunch of settings that I forgot to change. Torque management, copying the good fuel spark tables to the bad/mean, etc. Just a few other things. Loaded that file up and changed the plugs when I got home and did a nice launch with zero KR. Seems to be fixed now. The misfires went down a lot too after the plugs but there's still a few. The wires are old and I just had them in the garage. I'll pick up another cheap set this week and see what it does.
    It's also rich as FFF. 9.5 a/f FTW (not really). I got it up to high 10's now. Hopefully next Sunday will net me mid 12's. My 2nd run today I went 14.5@ 99 with a junk 60'.
  1. Traction control light only traction control
    By ccoimbre in forum General Grand Prix Discussion
    Last Post: 02-09-2014, 01:02 PM
  2. ABS and Traction Control not working but no ABS or Traction Control lights
    By jruether11 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2013, 04:40 AM
  3. Traction Control Off / Stability Control Off / Service ABS System
    By compro in forum Brakes/Suspension/Chassis
    Last Post: 12-21-2012, 09:37 AM
  4. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  5. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
