In the CALIBRATION DATA > FUEL > TORQUE MGMT folder: - Torque Abuse A/F - change it to 11.7
- Torque Abuse Differential Score A/F - change it to 11.7
- Traction Control Desired A/F - change all cells to 11.7
- Torque Abuse Drive Injector Disable - change it to 0
- Torque Differential Score Injector Disable - change it to 0 - Traction Disable Injectors - change all cells to 0
- Disable All Injectors High MPH - change all cells to 255 - Disable 1 Injector High MPH - change it to 255
- Disable 2 Injector High MPH - change it to 255
- High RPM PN Fuel Cutoff:
High Threshold: change it to 4005 RPM Low Threshold: change it to 4000 RPM
- High RPM Rev Fuel Cutoff:
High Threshold: change it to 3505 RPM
Low Threshold: change it to 3500 RPM - High RPM Fuel Cutoff:
High Threshold: change it to 7005 RPM
Low Threshold: change it to 7000 RPM
In the CALIBRATION DATA > SPARK > TORQUE MGMT folder: - Torque Abuse Spark - change it to 0
- Traction Spark Retard:
TCSMode1- changeitto0 TCSMode2- changeitto0 TCSMode3- changeitto0 TCSMode4- changeitto1 TCSMode5- changeitto2 TCSMode6- changeitto3 TCSMode7- changeitto4
- Traction Extra Spark Retard: change all cells to 0
- Torque Differential Score Retard - change it to 4
- Torque Abuse Speed Enable - leave at stock setting
-Torque Abuse Throttle Enable - leave at stock setting
-Torque Abuse RPM Enable - leave at stock setting
-Torque Abuse Time Enable - leave at stock setting
-Torque Abuse Spark Retard - leave at stock setting
-Torque Abuse Differential Score MPH Enable - leave at stock setting
Thanks man. That's what I was looking for. Guess I'll fire up the lappy386 tonight and change some stuff .
03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
