Thread: maf tuning help please
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 83
  1. #41 Re: maf tuning help please
    Dec 2013
    laporte mn
    Dhp all the way
  2. #42 Re: maf tuning help please
    Apr 2015
    Columbus, OH
    Dhp scanner was flaky for me when trying to use the analog input on my avt-852 for wideband. The WB would stop responding after a couple minutes, though the gauge was working fine.
    And I use an AEM wideband so it wouldn't work with uvscan. Finally just went the egr route. Now if I could just figure how to get Table Modifier to read my wideband data.
    Top Swapped 01 Imp
  3. #43 Re: maf tuning help please
    Dec 2013
    laporte mn
    Yeah I was looking at that last night. How does that exactly work. I would like it to read mine as well
  4. #44 Re: maf tuning help please
    Kemmerer, Wyoming
    if you have a plx or lc-1 wideband with a serial/usb output from the gauge, then you can go into your uv scanner options and enable it. there is a maf smoothing guide that you can use your wideband data with, but I haven't used it much, so I couldn't offer any help.
    https://www.dropbox.com/s/uy9aa1bkfh...-2003.doc?dl=0
    https://www.dropbox.com/s/jsavdi1h40...2003.xlsx?dl=0
  5. #45 Re: maf tuning help please
    Arizona
    Hptumers does have the ability for standalone data logging and 0 5 volt inputs
  6. #46 Re: maf tuning help please
    Kemmerer, Wyoming
    Quote Originally Posted by 91parkave View Post
    I realize this, but you either have to rig it to work with an egr wire or pay more to get the pro version. if there is a way other than these two methods, by all means, share with us on how to do it.
  7. #47 Re: maf tuning help please
    Arizona
    You stated it's really sad hptuners doesn't have the ability. I just said it does naturally being the pro version
  8. #48 Re: maf tuning help please
    Kemmerer, Wyoming
    My point was that you have to pay extra to get that input
  9. #49 Re: maf tuning help please
    GTP Level Member
    Jan 2015
    Lincoln, NE
    gotta pay to play...
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  10. #50 Re: maf tuning help please
    Kemmerer, Wyoming
    I've heard rumor that the beta hp tuner software incorporates serial/usb inputs from aux sensors. if that is true, I wont need the pro version or have to run a wire to the egr to scan for wideband data with the hp tuner.
  11. #51 Re: maf tuning help please
    Arizona
    You need pro if you want a direct input to the box otherwise use the egr or whatever wire u want and use the wide and that way. It's just as easy and you save a lot of money
  12. #52 Re: maf tuning help please
    Dec 2013
    laporte mn
    So I need some assistance again. When u guys tune for not, do u go full throttle? These tuning guides I downloaded are telling me to ease into it, but if I ease into the throttle I don't see any knock but if I floor it I see kr
  13. #53 Re: maf tuning help please
    Dec 2013
    laporte mn
    And also do I export a new mg/cyl table every time I do a maf table out of table modifier as well or no?
  14. #54 Re: maf tuning help please
    no on the mg/cyl table.
    i mix it up, local, highway jump on it on the highway, run it from a dig. normal driving as well.
  15. #55 Re: maf tuning help please
    Dec 2013
    laporte mn
    All in one scan?
  16. #56 Re: maf tuning help please
    yes. drive around for a good 20 minutes.
  17. #57 Re: maf tuning help please
    Dec 2013
    laporte mn
    Oh see my scans are only like a minute long. Could that be hindering my results
  18. #58 Re: maf tuning help please
    lol yes. it needs to see all ranges.
    put back the stock file, let the trims re learn, then take it out for a 20 minute scan.
  19. #59 Re: maf tuning help please
    Dec 2013
    laporte mn
    That's what I'm doing. It will be going back to a stock tune with Lq4 maf table
  20. #60 Re: maf tuning help please
    you may still have to do it 3 or more times. its hardly ever perfect the first time out.
  1. 3.29 to 2.93 Tuning
    By wa04compg in forum PCM Tuning
    Last Post: 06-27-2013, 10:23 PM
  2. Tuning help in NYC
    By buickman104 in forum PCM Tuning
    Last Post: 10-11-2012, 08:02 PM
  3. PCM Tuning
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 10-11-2012, 08:13 AM
  4. Tuning Amp
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2010, 09:30 PM
