Thread: maf tuning help please
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 83
  1. #1 Re: maf tuning help please
    Dec 2013
    laporte mn
    I understand I'm just trying to figure out how to do this the right way so I can get it tuned. I have 17 days before the proving grounds and I want to drop a pulley size still but I'm seeing kr with a stock pulley with SD headers, 1.84 roller rockers, and 4" intake on a 04 comp g
  2. #2 Re: maf tuning help please
    i tuned about 5* of KR out of my car, using eddies only. its doable.
    make sure the o2 is not hitting the fire wall, that can cause false KR.
  3. #3 Re: maf tuning help please
    Dec 2013
    laporte mn
    OK so I did a very bad thing last night.
    I think I bricked my ecu. I was writing a tune and half way through my laptop shut down for some restart nonsense. I started it back up and tried to connect to the ecu again and it says that it has no osid and there is no Vin in the ecu. So I tired writing to it. I got a full write in the vehicle. And all the light in the car come on and I try to start and the gauge cluster goes black and it won't crank.
    Do I need a new ecu? And if so do I need to take it to a dealership? Its an 04 comp g
  4. #4 Re: maf tuning help please
    Arizona
    Leave battery disconnected for a couple hours try and write again
  5. #5 Re: maf tuning help please
    Dec 2013
    laporte mn
    OK I will do that.
  6. #6 Re: maf tuning help please
    sounds like it needs a security learn. if you wrote a bin file to it thats not the same as your cars that can happen.
  7. #7 Re: maf tuning help please
    Dec 2013
    laporte mn
    How do I go about security relearn? And it does pop up on my dic that theft system not programmed
  8. #8 Re: maf tuning help please
    i set the timer on my phone for this and walk away so im not trapped in the car lol
  9. #9 Re: maf tuning help please
    turn key to and try to crank, leave it at run for 10 minutes, then turn it off for 10 seconds, then try to crank it and leave it at run for 10 minutes, then off for 10 seconds, then one more time, the 4 th time it should crank and fire up.
    during this, turn the parking lights off, (put ebrake on) the radio, hvac. roll the window down, do the key turning from outside the car. if your battery is weak, put a charger on it cause the key will be to run for 30 minutes and if the battery dies your starting over.
    do not open the door or operate anything in the car during this.
  10. #10 Re: maf tuning help please
    Dec 2013
    laporte mn
    So shut radio off, fan off, put ON ebrake, roll down window and move key from outside. Sounds good I'll try it when I get home from work
  11. #11 Re: maf tuning help please
    ive had to this a few times after installing new pcm's or a full reflash with a different ossi #.
    being you crashed during the write the pcm may be blank now and its just needs the security learn done.
  12. #12 Re: maf tuning help please
    Dec 2013
    laporte mn
    I'm going to try. Is there any way I could go to something like a 05 ecu. They have a lot more table to modify than a 04
  13. #13 Re: maf tuning help please
    pretty sure you can use the 05, but you would need to flash the 04 bin to it i think. i maybe wrong tho. i dont know much about the 05 pcms themselves.
  14. #14 Re: maf tuning help please
    Dec 2013
    laporte mn
    OK. I'll just stick with my stock one if that security thing worls
  15. #15 Re: maf tuning help please
    Dec 2013
    laporte mn
    Thank u scottydoggs I did the security relearn and the car fired right and runs good now
  16. #16 Re: maf tuning help please
    awesome.
  17. #17 Re: maf tuning help please
    Dec 2013
    laporte mn
    So went to start my car up today and my battery is now dead so I jumped it and it went into reduced power mode and won't tell me my fuel level
  18. #18 Re: maf tuning help please
    unplug the battery for a while, charge the battery or have it tested. as well as the alt. leaving the battery off should reset the pcm and maybe its normal when you hook a fully charged battery up.
    see if you left a light on or something, it died for a reason.
  19. #19 Re: maf tuning help please
    Dec 2013
    laporte mn
    OK will do. I just figured it might have something to do with the ecu issue
  20. #20 Re: maf tuning help please
    dead battery is a new problem.
  1. 3.29 to 2.93 Tuning
    By wa04compg in forum PCM Tuning
    Last Post: 06-27-2013, 10:23 PM
  2. Tuning help in NYC
    By buickman104 in forum PCM Tuning
    Last Post: 10-11-2012, 08:02 PM
  3. PCM Tuning
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 10-11-2012, 08:13 AM
  4. Tuning Amp
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2010, 09:30 PM
