Thread: Trans shift time, pressures, and force motor current
Results 1 to 7 of 7
  1. #1 Trans shift time, pressures, and force motor current
    Mar 2015
    USA
    So decided to tinker around with hptuners on my car. I want to firm up and speed up the shifts a bit, but nothing crazy. Mostly to prolong the life of the tranny during daily driving.
    I've been comparing a lot of files to the stock tune, but they seem to be all over the place. I don't trust any of them to copy those tables into my file.
    Any general recommendations, or anyone want to share their file?
    FWIW, it's a 2004 Impala SS with high miles on the trans.
  2. #2 Re: Trans shift time, pressures, and force motor current
    I just set the shifts to .300 and upped the line pressure by 10%.
    I was also running a shift kit.
  3. #3 Re: Trans shift time, pressures, and force motor current
    Arizona
    I have the diy shift kit on .175 shift times with a 5 to 10 % increase at varying throttle positions
  4. #4 Re: Trans shift time, pressures, and force motor current
    Mar 2015
    USA
    Quote Originally Posted by 91parkave View Post
    So you guys are running a flat .3 or .175 across the board on the shift time tables? What confused me about most of the tunes in the repository is in the lower ft lb colums they sped the shifts up, but in the higher levels they actually slowed them down.
    And the 5-10% bump up under the force motor current tables?
    I just actually changed the fluid and filter. If I realized how easy the transgo shift kit was, I would have done it. Still might order it and pop it in.
    Thanks!
  5. #5 Re: Trans shift time, pressures, and force motor current
    Arizona
    That's usually done cause at wot sometimes the transmission can't shift in time. So the shift is delayed to meet the commanded shift time
  6. #6 Re: Trans shift time, pressures, and force motor current
    I never touch the force motor current, just change the line pressure.
    There is a normal and performance mode under shift pressure. I add 10% up to 450 ft lbs.
  7. #7 Re: Trans shift time, pressures, and force motor current
    Mar 2015
    USA
    Finally gave that a shot. So far so good. I went .300 across the board up to the point where stock times were lower. Didn't touch the 3-4 times either since they were already around .275
    Bumped the upshift pressures up by 10%
    Think I'm still gonna do the transgo kit too..
  1. 97 Grand Prix Normal AC Vent Temperatures and Pressures
    By mainecrab in forum General Tech Discussion
    Last Post: 07-08-2014, 08:48 PM
  2. Upping line pressures with dhp
    By dsmuts in forum PCM Tuning
    Last Post: 04-19-2013, 08:52 AM
  3. Trans takes a long time to shift from 1st to second, one it does it is good
    By hampshire32000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-09-2011, 03:47 PM
  4. Estimated Drag time of my car wiht current mods
    By screamingreenmonster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2011, 12:54 AM
  5. Transmission operating pressures
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2008, 10:35 PM
