So you guys are running a flat .3 or .175 across the board on the shift time tables? What confused me about most of the tunes in the repository is in the lower ft lb colums they sped the shifts up, but in the higher levels they actually slowed them down.
And the 5-10% bump up under the force motor current tables?
I just actually changed the fluid and filter. If I realized how easy the transgo shift kit was, I would have done it. Still might order it and pop it in.
Thanks!
