Thread: Logging AEM Wide Band O2 with DHP analogue input
Results 1 to 3 of 3
  1. #1 Logging AEM Wide Band O2 with DHP analogue input
    GTP Level Member buickman104's Avatar
    NYC
    I am finally ready to start using my wideband to tune. I read this post that shows how to use the EGR brown wire to read the voltage output from the wideband to tune.
    http://www.grandprixforums.net/threa...R-using-UVScan
    I was unable to find a write up for logging with the DHP green analogue connector that connects to the box. I was wondering if anyone had any info on what pin should I connect the 0-5V output wire to? And how to calibrate it using UVscan? I would like to log my wideband without having to go through the EGR connector if possible.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Logging AEM Wide Band O2 with DHP analogue input
    Florida
    the dhp has a label on the side which is ground and the other three inputs. once it is plugged in just log it in what ever scaner you use. but egr is deff the best way to go. no extra connections to fool with, tangle or break.
  3. #3 Re: Logging AEM Wide Band O2 with DHP analogue input
    NYC
    Thanks for the advice z34Phoenix. I decided to go with running the wire up through the EGR.
  1. Wide Band Logging thru EGR using UVScan.
    By Z34Phoenix in forum PCM Tuning
    Last Post: 01-07-2014, 09:55 AM
  2. Gtp meth etc wide band question.
    By ctspoolintsi in forum PCM Tuning
    Last Post: 06-28-2012, 11:54 PM
  3. Wide Band Question
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-16-2009, 06:50 PM
  4. Good Wide band
    By TheOtherNick in forum General Tech Discussion
    Last Post: 05-24-2009, 01:00 AM
