Thread: Tuning out egr?
Results 1 to 8 of 8
  1. #1 Tuning out egr?
    gardner,mass
    So i need to go get a sticker and i need to make it so 1 i can still have my wideband hooked up threw the egr plug and 2 so the readyness test will pass. What do i need to do to the codes exactly in hpt? I have to have egr enabled to use the wideband threw it so is there a way to make the codes not show without turning off egr?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Tuning out egr?
    set the codes to no reporting. at least thats what you do in dhp.
  3. #3 Re: Tuning out egr?
    Nov 2011
    NY
    I "read" once that you could:
    Set 'all' the codes to no report as the drive cycle test will then be completed and you'll test just fine.
    hypothetically of course... As I don't believe it is technically ok to do this.
  4. #4 Re: Tuning out egr?
    you have to delete a lot of codes to do that lol
    egr is like 3 codes you delete. aka set to no report. then in dhp is another folder with the same codes, you set the values to 0 next to the same codes.
    at least in dhp, no clue how htp works.
  5. #5 Re: Tuning out egr?
    Feb 2009
    flintnasty MI
    or you could just set the EGR enable point at 255 degrees.
  6. #6 Re: Tuning out egr?
    gardner,mass
    I want the egr enabled so i can read my wideband threw it...
  7. #7 Re: Tuning out egr?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Ginseng View Post
    That still works.
  8. #8 Re: Tuning out egr?
    Arizona
    The voltage will still be there, setting it to no report/and or setting egr temp to max just means it won't set off the check engine light.
  1. 07 tuning
    By Seachicken in forum PCM Tuning
    Last Post: 02-19-2014, 05:19 PM
  2. pcm tuning
    By Matt Palm in forum Midwest
    Last Post: 04-12-2012, 07:57 PM
  3. tuning in BC
    By sugaryuk in forum Canada
    Last Post: 12-19-2010, 09:14 PM
  4. tuning
    By grand2000prixgtp in forum PCM Tuning
    Last Post: 11-19-2009, 04:10 PM
