I have a 2001 gtp and i am having a problem with my keys and security i think its alarm related but i want to disable my security system using dhp can someone help me out
iirc, the security is in the ignition switch, not the key. you can try using a resistor to force the security system to see a good signal, maybe.
IMO, i would just go to the junk yard and get a replacement switch and key. you will have to carry around 2 keys but its better than the car not starting.
In DHP, it's not under security.. Fuel cutoff is under fuel timer or some silly thing like that. Take a look around, unfortunately I'm not in front of it and can't look right now.
Thanks for your opinions but i. Looking to do it with dhpso there will be now hassle later
It's not my opinion.. I've done it..... with dhp. It's in a goofy area... so I gave you a good idea of how to find it since I'm not in front of DHP. If you'd like a link to a tune that has it done, I can supply that as it's in my dropbox.
Yes i would really appreciate it thank you
