I just installed a scytek p-10 in my car and everything works great, EXCEPT, i cant get the parking light flash or headlight flash when u lock and unlock for anythingi do not have a factory alarm. 2000 gp se, any help?
where did you hook up the white wire? did you test it before hooking it up?
brandon
yeah i put a multimeter on the white and their was an output. i tried connecting to the brown wire on the lightswitch first for the parking lights.nothing. then i tried the yellow for the headlights. again, nothing.![]()
It should be the brown wire. Put a meter on it and turn the switch you should have 12volts, if not you;ve got something wrong, check fuses.
brandon
I would try adding the relay, it may not put out enough juice to kick them over. That'r thats the only thing i canthink of.
brandon
